Steering wheel wobble at low speeds
Results 1 to 14 of 14
    Aug 2007
    4
    My father's 2001 v6 (4-motion) passat wobbles the steering wheel back and forth when driving at very slow speeds <10mph. If you let go of the wheel, it will rock back and forth about an inch, and slowly steer itself to the right. At higher speeds it becomes felt as a vibration in the steering wheel.
    So far I have checked the suspension parts for looseness just by trying to move them with my hands. Everything seems okay to me. I jacked up both front wheels and checked for play side-to-side and up-and-down, again they seemed solid. I took off both front wheels and checked the drive shafts. Boots are in good condition but I did notice that you can rotate the outboard joint/hub/disc about 1/4 inch with the drive shaft held in place with locking pliers. I thought cv joints where not supposed to have any play in them at all? Could this be the cause of the problem? The car only has 25k miles...it's hard to believe both outboard cv joints have worn out internally. My other suspect is tie-rod ends, what is the best way to check those out?
    Any help would be appreciated.
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    53
    24,324
    You have a bent wheel or a bad tire. The disc is held in place by the lugs, so without them, you can rotate it. I doubt your problem is CV or axle related.
    Aug 2007
    4
    I rotated the tires (fronts to back and backs to front) and there was no change whatsoever...the steering wheel continues to pulse back and forth in exactly the same manner. I can't see the tires/rims being the problem..there should have been some change occuring. Thanks anyway..it was worth a try.
    4th Gear
    Apr 2007
    Knoxville,TN
    34
    3,557
    Does it do it when you break at low speeds? Cause that could be a rotor.
    Apr 2004
    SoCal
    2,117
    Quote Originally Posted by Jayson13f View Post
    Yup...could be a warped rotor.
    Try putting on a different set of wheels (if you have any). That's a quick way to see if that will affect the vibration. Your back wheels can have dents too. They usually are not visible to the eye.
  7. #6
    Aug 2007
    4
    Applying the brakes makes no difference..it still wobbles the steering. Unfortunately I have no other set of wheels to try. Thanks for the recommendations.
  8. #7
    4th Gear
    Oct 2005
    Austin TX
    3,271
    How are the tie rod ends? Lock the steering wheel and grab the tire on the sides. Try to move it side to side as if you are steering. It should not move at all. You may need to jack it up to do this if you are not really strong.
  9. #8
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    53
    24,324
    Quote Originally Posted by LordBlatz View Post
    You could have 2 or more bent wheels. I have seen it happen (to 15" steelies). If the wheels/tires and brakes are ruled out. Start checking the tie rod ends and control arms. CV joints should not make the wheel rock at low speeds, but can make it vibrate at higher speeds.
  10. #9
    Oct 2004
    Augusta, GA
    141
    I have also had this happen to me before with high mileage tires. No obvious defects etc....... but when I changed the tires out the problem went away. If all 4 tires are same vintage / milage try your full size spare and see if it changes.
  11. #10
    Punches Dubs. True Story
    Mar 2005
    Butler Lake Park
    39
    9,984
    Blog Entries
    48
    Hell, I'd pay the $40 or whatever for my local tire shop to rotate and spin balance the tires. Based on the low speed wobble, I'd still be looking at a wheel that's out of round ...which would be identified by a balance.
  12. #11
    6th Grade
    Feb 2003
    MO
    14,918
    Tire is most likely. CV joints and suspension components are way, way, way down the list. Few tires are actually round, and on cars with one out of round tire in a matched set of four, they're usually all unroundish.
  13. #12
    Aug 2007
    4
    Well the problem did turn out to be a tire. Had each tire put on a wheel balancer and one tire had a belt let go. Funny how rotating tires front to rear did not change the problem symptoms..that threw me off the trail for a while. In the future I'll try using the spare tire or a known good tire to help identify wheel/tire problems.
    Thanks to everyone for their helpful suggestions.
  14. #13
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    53
    24,324
    Glad you got it fixed.
  15. #14
    Aug 2007
    Maryland
    47
    2,261
    x
  16. Remove Advertisements
Human Verification
