How to replace spark plugs on 01 passat 1.8T
Results 1 to 30 of 30
    Apr 2007
    17
    Hey just need to replace some spark plugs on the passat. I have an 01 1.8T 20v , I guess they are all bad.
    6th Gear
    Jun 2006
    Bklyn NYC
    9,416
    if you can open the hood on a 1.8t and dont know how to change the sparkplugs then you dont need to be touching anything in the engine bay... leave it to the pros
    Founder of the STFA
    Feb 2003
    Ohio
    8,667
    First you put the car up on jack stands, then...
    Overdrive
    Jan 2006
    Fargo ND
    32
    11,880
    Quote Originally Posted by beatzilla2004 View Post
    1. Make sure you have tools to do it(screwdriver flat, 5/8 spark plug socket with rubber insert, 10 extension(make sure its the kind that locks to the socket or you will have issues), Ratchet, Torque wrench, may need a 6mm allen to remove the coilpacks if you have the old style bolt down ones)
    2. Open Hood
    3. Remove engine cover(the plastic on the top of the motor) its held on my three half twist screws
    4. remove coilpack, if you have the type that bolt down you use a 6mm allen, other wise you pull up if you don't see bolts
    5.remove spark plug(5/8 socket)
    6. Check gap on new plug, make sure to hand thread it in
    7. tighten to 22FT lb(someone correct me if I'm wrong)
    8 insert coilpack
    9. repeat for other 3,
    10 put covers back on
    11. Fire up the motor, make sure it runs good.
    Grinding Gears...gone fishing! ScottPassat2.8's Avatar
    Feb 2005
    Staten Is. NY GLX2.8
    47
    22,620
    if you have never changed plugs you must be real careful you dont cross thread the new ones going in.
    are you mechanically inclined?
    do you have tools?
    are you patient?
    if you can answer yes to these then you can do it.
  7. #6
    5th Gear
    Mar 2005
    Dallas, TX
    41
    6,245
    Be careful when you put the plugs in - gently hand tighten it first, then use the ratchet/torque wrench so you dont cross thread anything. Also put a bit of anti-seize on the threads first.
  8. #7
    2nd Gear
    Jul 2003
    Montreal - non vw
    52
    589
    One great tip from the bently manual is to have a piece of rubber hose that can fit over the end of the spark plug. Much easier to place the plug down in the sleeve this way.
  9. #8
    Founder of the STFA
    Feb 2003
    Ohio
    8,667
    Put the new plugs in using only a spark plug socket and a 6-8" extension to help with the threading alignment. No ratchet. You should almost be able to get them tight enough like this to go straight to the torque wrench.
    Purple is , the torque is 22 ft/lbs.
    Little thing, but I usually take all four out consecutively, then put all four in. The coilpacks really can't 'be crossed up due to the short leads.
  10. #9
    Overdrive
    Jan 2006
    Fargo ND
    32
    11,880
    Quote Originally Posted by ONE8T View Post
    Same way I do it too, just didn't want to confuse someone new to doing.
  11. #10
    Apr 2007
    17
    this is all really good info, im not mechanically inclined....but new to it and wanna pick it up.
    what do you mean by tighten 22ft/lb of torque?
  12. #11
    Feb 2005
    47
    22,620
    http://en.wikipedia.org/wiki/Torque_wrench
    you can get a decent one at sears.
  13. #12
    Moderator Extraordinaire
    May 2000
    San Angelo, TX
    54
    13,746
    I'd put antisieze on the threads of the new plugs before putting them in. Just a little to keep the steel plug threads from bonding to the aluminum head over time.
    Original Club B5 member: 16 Golf 4. Missing my 99 B5 & 08 R32
  14. #13
    Apr 2007
    17
    Little problem, i was just going thru the job before i actually do it with the parts...I couldnt unscrew the engine cover because it kept on clicking to a lock back in place, what is the method in taking these special screws off?
  15. #14
    Feb 2005
    47
    22,620
    1/4 turn. they dont unscrew, they unlock.
  16. #15
    Overdrive
    Jan 2006
    Fargo ND
    32
    11,880
    IF you wait until tomorrow I will have a right up with pictures.
  17. #16
    Apr 2007
    17
    Quote Originally Posted by scottpassat2.8 View Post
    Roger that, thanks much!
  18. #17
    5th Gear
    Mar 2005
    Dallas, TX
    41
    6,245
    A torque wrench is helpful but not required. On the NGK's they had directions as to how to torque them down. Something like - after tightening by hand, turn 1/4 turn with a ratchet, or something similar. It will get them tight enough. Just use common sense and you wont over tighten them.
  19. #18
    Feb 2004
    Midcoast Maine, USA
    1,057
    I've also read that you should only change spark plugs when the engine is cold. I let my car sit overnight and changed them in the morning.
  20. #19
    Sep 2006
    plano, tx
    29
    13,908
    Blog Entries
    5
    of course you should only change them when cold!!!!!!
    rule of engine work NUMBER ONE.
    never change something directly touching,in, or around the engine while it has been freshly run or is hot.
    now, all you morons out there can choose not to heed my advice if you decide you don't want to. less contest in the gene pool
  21. #20
    Founder of the STFA
    Feb 2003
    Ohio
    8,667
    Quote Originally Posted by sipes216 View Post
    How did I miss that rule? Seriously, you shouldn't open your coolant reservoir when it's hot or do a turbo swap, but what's the problem with anything else? It depends on what your hands/arms can take. I'd never get anything done if I waited for the car to cool down every time I was tweaking something.
    I'd say rule of engine work NUMBER ONE should be don't work on it when it's running.
  22. #21
    4th Gear
    Mar 2005
    Boston MA
    29
    2,944
    make sure you set the gap for the plugs too
    this is a DIY guide
    http://www.a4mods.com/index.php?page...pperplugs.html
  23. #22
    Apr 2007
    17
    ok spent a good hour today replacing the air filter...saw my corroded check valve...huge hole in it!!! yikes...
    When i got to the spark plugs, engine was cool....i couldnt even unplug the coils....what it the trick to those....one was already loose and came off and when i got past that i couldnt even get off the coil! Im reading from the bentley manual....what am i doing wrong?
  24. #23
    5th Gear
    Mar 2005
    Dallas, TX
    41
    6,245
    On the top of the coil where the wiring plugs into the coil, there should be what looks like a little tab, or slot (forget what it exactly looks like) that acts as a clip that somewhat secures it on. I gently wiggled it with a screwdriver and it loosened up.
  25. #24
    Overdrive
    Jan 2006
    Fargo ND
    32
    11,880
    Ya those B5.5 can be tough. Yesterday for fun I timed my self to see how long it would take.
    I use the following tools
    Ratchet(wierd swivel type which is faster) with 10" extension and 5/8th plug socket(rubber insert)
    Torque wrench with differnet 10" extension and plug socket
    screwdriver
    5mm allen for the Coil packs
    Feeler gauge
    Took me under ten minutes with opening the hood, gap and start up at the end.
  26. #25
    Sep 2001
    NoVa
    311
    The B5 01's (AUG) coilpacks do not require a 5mm allen wrench. They are held in by friction. You need to carefully pull straight up until they give. But be ready for it to give so you don't bang it when it does go. There may be a harness tie-down clip you will need to remove in order for there to be enough slack to pull up.
  27. #26
    Aug 2006
    31
    improper gaps
    In the past I never was one to check the gap on new plugs that I put in. I always assumed the quality control at the factory ensures they are properly set . What exactally is the importance of the gap and what will happen if the gap is off? Looking at the DIY writeup that was earlier linked, (http://www.a4mods.com/index.php?page...pperplugs.html), the plugs in his car were all gaped differently form the factory. What will this do to the performance of the plugs and the engine?
  28. #27
    Feb 2007
    san diego
    341
    Really easy, takes 15 mins top
  29. #28
    Apr 2007
    17
    Quote Originally Posted by JoshAUG1.8T View Post
    HAH! yeah, im not a mechanic, but im not mentally challenged either....i cracked one coil harness trying to find which push will release the harness....you got the little hole in the top...thinking maybe if you poke on it, it will unlatch and you can pull...no. Then you got the mechanism in near the wiring that you can either push or pull back thinking maybe that will unlock the harness....Well i tried all and no luck...i will try more tomorrow with maybe better luck. But once i get the harness off i just pull straight up on the coil packs? Do i need to wiggle, twist, or turn? Do i need to be careful of breaking anything?
  30. #29
    Apr 2007
    17
  31. #30
    Feb 2007
    san diego
    341
    Yes the coil pack pop right off, just pull up and you'll hear that little pop noise. Be carefull not to hit the coil pack on the inside of the valve cover.
  32. Remove Advertisements
Human Verification
