How to clear front and rear sunroof drains?
Page 1 of 2 12 LastLast
Results 1 to 30 of 31
Like Tree2Likes
Thread: How to clear front and rear sunroof drains?
    ems
    ems is offline
    Jun 2004
    Central Massachusetts
    1,268
    Help? Have been dealing with water on my right front and rear (mostly rear) floor for at least a month now. Followed the "how to" instructions and confirmed that it is NOT the polen filter (thanks for the help btw).
    Have tried to do it myself and have had my car at the shop twice and no one knows how to do it. Spent the last hour searching other posts, and have not been able to find any "how to" directions.
    THis is turning out to be a majo PIA. Can someone please steer me towards a fix?
    Thanks
    Jan 2006
    San Lorenzo, CA
    23
    cleaning out sunroof drains
    I had this problem on my old Jetta and I used compressed air (adjustable blow gun attached to my air compressor). I then found one of the drains (rear) had come loose and was draining into the truck area. I know this is not Passat related but VW likes to keep using old designs where they can.
    Hope this helps,
    John French
    ems
    ems is offline
    Jun 2004
    1,268
    Quote Originally Posted by john french View Post
    Hope this helps,
    John French
    I think that is my problem as well, except that it is draining to the rear floor. Have already blown them out with an air gun with no result.
    Am trying to find some sort of an instruction or schemation on how totroubleshoot, breakdown and repair???
  5. Remove Advertisements
  6. #4
    Grinding Gears...gone fishing! ScottPassat2.8's Avatar
    Feb 2005
    Staten Is. NY GLX2.8
    48
    22,620
  7. #5
    PassatWorld Staff
    Jun 2002
    Albuquerque, 1.8T A
    12,267
    I would think that blowing them out with an air gun could cause more harm than good. If they are severely clogged, seems like the drain line might blow loose in a concealed place - who know where? - then that's where the water would drain.
    The accepted method is to squeeze the drain nipples (don't get all excited now!), part 32 in Scott's diagram.
  8. #6
    Fore!
    Dec 2001
    Riverside CT
    49
    1,558
    Try running some water from a hose over the sunroof, and see if you can identify where it comes in.
    I used the bentley recommended way to clean out the drains with a piece of throttle cable, and ended up disconnecting one of them inside the a-pillar, resulting in a major leak at that point. I had to drop the roofliner to reconnect it.
  9. #7
    ems
    ems is offline
    Jun 2004
    1,268
    Quote Originally Posted by Rusty View Post
    Thanks Rusty.
    Can you tell me where on the car part#32 is located (front and back) is located? That is not clear from the diagram.
    thanks again,
  10. #8
    5th Gear
    Mar 2003
    Louisville, KY
    6,172
    Quote Originally Posted by ems View Post
    At the bottom of the A and B pillars... open the door and look way down near the bottom of the frame. They are small black rubber "nipples" about the size of the last joint on your pinky finger. Pinch until the flaps unstick & open up (kinda like how the valves on the camelback or platypus water sacks work).
    If you spray a small amount of silicone lube up into the slit in the nipple, that should keep the flaps from sticking together again.
  11. #9
    ems
    ems is offline
    Jun 2004
    1,268
    The good news is that I think I finally cleared the leak from cleaning out the drain area and blowing with lp (20psi) air.
    The bad new is the I spent over an hour fishing around the A&B pilars underneath the car and simply cannon find the "nipples"/drain tubes. THough I found the one in the A pilar, and then when I test with water from sunroor drain it drained out from underneath.
    DOes anyone have a diagram or picture.
    merry christmas
  12. #10
    ems
    ems is offline
    Jun 2004
    1,268
    Quote Originally Posted by pete1 View Post
    I wonder if that design has evolved with the B5 --> B5.5? I am not seeing anything in or on the A/B pilars resembling what you described?
    Are they by chance under the plastic rocker panel molding?
  13. #11
    5th Gear
    Mar 2003
    Louisville, KY
    6,172
    Instead of the B pillar, the rear drain may be in the rear wheel well... look for post #10 here:
    Questions regarding Sunroof Drain Tubes...
    Also, the tubes themselves may be disconnected from the nipples... see post #12 here:
    Sunroof Drain Nipple
    I'm not sure if the drains are only on the driver's side (two drains total), or on both sides (four drains total).
    I'll try to take some pictures tonight...
  14. #12
    ems
    ems is offline
    Jun 2004
    1,268
    THANKS! I gotta figure this one out. Neither my local mechanics, body shop or vw dealers will touch it.
  15. #13
    5th Gear
    Mar 2003
    Louisville, KY
    6,172
    sorry I didn't get to that pic... I'll try again tonight...
  16. #14
    ems
    ems is offline
    Jun 2004
    1,268
    bump... Pete?
  17. #15
    4th Gear
    Oct 2004
    SWFL
    3,307
    There are four drains, on at each corner of the sunroof.
    VW dealer cleaned mine once for 110.00.
    It was leaking (A pillar drivers side) and it was under warranty, so I took it in.
    I had a habit of cracking the sunroof and parking under trees for shade.
    I lived in SWFL at the time - an expensive introduction to sunroof drainage.
    On a B5.5 sedan, the rear drains are in or behind the rear wheel liners. Maybe even behind the bumper somewhere?
  18. #16
    5th Gear
    Mar 2003
    Louisville, KY
    6,172
    bump... Pete?
    Sorry... too busy at work.
    Here's two photos of the driver's side front drain (click for larger image):
    I thought the front drains were located near the bottom of the pillar, but they are above the "accordion boot" instead. Oops.
    Passenger side front drain is the same as the driver side.
    I'll try to locate the rear drains this weekend (I think they are up inside the rear wheelwells, hidden behind the wheelwell paneling.
  19. #17
    ems
    ems is offline
    Jun 2004
    1,268
    THANKS Pete!!! Should have responded sooner, but have been traveling.
    Your pictures were a big help, and really helped me to identify the leak/break. Turned out that the hose/line behind the nipple is where the break was. Think that I have FINALLY got it fixed !?!?!?!? (I hope). THis was not an easy one to trace.
    THanks again.
  20. #18
    5th Gear
    Mar 2003
    Louisville, KY
    6,172
    Good to hear you got it fixed!
    Where did the rear drains turn up? (I'm guessing they are up inside the rear wheel well, hidden below the black plastic "liner")
  21. #19
    ems
    ems is offline
    Jun 2004
    1,268
    To be honest with you, I gave up after finding/fixing the front leak. When I tested for the rear drain, the water did come out from behind the wheel, and I hope that was ok.
    I;ve traced and repaired a number of problems on this car over the 6+ years I've had it and this one has turned out to be the most elusive pia so far.
    THANKS AGAIN!!!! You saved my a-- on this one.
  22. #20
    Jan 2013
    Salisbury MD
    86
    Just found and unclogged my front two. A nice tool I used was a left over turkey baster from t-giving lol. Just fill with water and wedge it in the drain as far as you can and fist it. Black crap shot right out. I hear the rear drains are the tough ones.
  23. #21
    GCM
    GCM is offline
    Mar 2011
    FL
    37
    Rear sunroof drains can be accessed from inside the trunk by removing the side trim panels.
  24. #22
    May 2014
    Ireland
    5
    Hello guys. I am plagued by water leaks in our passat.
    There is no sunroof so instead of a drain nipple near the hinges of the driver's door, there is simply a plug (broken though). What is the purpose of that hole in passats that do not have sunroof? Should I keep that hole open or seal it?
    I sealed the door panels, but today I noticed that after the rain, the amount of water increased again in the rear carpet (right driver's side). All door sills seam to be dry, except the driver's door sill looks suspicious. Still some water, although I sealed the door panel thoroughly...
    Thanks.
  25. #23
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    62
    11,819
    Water entering the front can easily migrate to the back. If you have no sunroof and the pollen filter seal is OK, check the drains in the water scuttle. They're under the battery and under the brake booster.
  26. #24
    May 2014
    Ireland
    5
    Hi. Thanks for your response. Drain holes in the plenum chamber (under battery and brake booster) are cleared. Pollen filter seal is torn, I only refitted it upside down because I did not have a replacement. I should soon get the sealing tape and complete the job. Nevertheless, I have a feeling that it has to be something else other than the pollen filter housing... The pollen filter is on the left side while water mostly accumulates on the right side (in the back in particular). If it was the pollen filter housing seal to blame, shouldn't the pond of water be on the same size?
    And that hole near the driver door's hinges (that is used for sunroof drain pipe for models with sunroof). Should I seal it? Where will water end up if I pour water in that hole? Thank you so much!
  27. #25
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    62
    11,819
    Quote Originally Posted by Antanas26 View Post
    If you mean side, then yes, that follows.
    Since if the hose is leaking, the water winds up in the footwell, then water going in where the hose comes out could well wind up in the footwell. I'd certainly plug it, even if I don't think much water would get in there. It's serving no purpose.
  28. #26
    May 2014
    Ireland
    5
    Thanks for your comments. Yes, I meant "side". Then I still have to find the source of that water ingress...
  29. #27
    Aug 2013
    United States
    65
    ??? where is that on the car?
  30. #28
    4th Gear
    Aug 2001
    Southern, AL
    55
    4,627
    ^ Open either front door, then look on the body above the top door hinge for an odd looking grayish-black piece of rubber with downward sloping sides that form a "V" . Press at bottom of "V" to get the flat edges of that rubber fitting to open.
    You'll know you're in the right spot when you start fingering that nipple to remove several years of accumulated debris.
  31. #29
    SuperCooled30V Moderator keithwbloom's Avatar
    Apr 2005
    In his workshop
    50
    4,559
    Blog Entries
    3
    You can also use a length of weed whacker trimmer line to fish/snake the full length of the drain tube from above and avoid blowing a hole in drain tubing with compressed air.
    VAGguy and V6er like this.
    B7 S4 Cabriolet 6MT, 8P A3 Tip, B5.5 SC/IC V6 5MT
  32. #30
    May 2006
    Abingdon, MD
    39
    22,530
    Quote Originally Posted by Electron Man View Post
    There was a dealer service action/recall where they snipped the "nipples" to keep them open and prevent clogging. Mine were done.
    Glutton for Punishment: 13 CC Sport Plus, 04 Passat 1.8T GLS Variant, 99 C-Red Passat 1.8T (crushed)
  33. Remove Advertisements
Human Verification
