Shocks or Struts?
Results 1 to 17 of 17
    Jan 2006
    Southern Indiana
    4
    Shocks or Struts?
    I've got a 1999 Passat GLX in need of new shocks. (@70,000 miles, very floaty, bouncy ride now, stock shocks) When I look on-line at parts warehouses, they list both shocks AND struts for 99 Passat sedan. I'm a little confused. When I look at the car, I belive there is a shock coming through the front spring. Can anyone enlighten me before I order parts? Does a 1999 Passat GLX sedan have front shocks or struts??
    Thanks for the assistance
    Jan 2006
    Canada
    110
    Shocks refer to the springs, and struts refer to the damper (cylinder filled with compressed gas). All cars have both shocks and struts. If you're feeling a very floaty ride, then your struts need to be replaced.
    2nd Gear
    Oct 2005
    CT
    31
    864
    Quote Originally Posted by afawal
    Really? I thought the B5 Passats have shocks in the rear and struts in the front?
  5. Remove Advertisements
  6. #4
    What time is Matlock on?
    Aug 2004
    over on TDIclub
    17,303
    Quote Originally Posted by B5Greg
    Bingo
    I think what he meant to say is cars have both SPRINGS and shocks/struts.
  7. #5
    PassatWorld Staff
    Jun 2002
    Albuquerque, 1.8T A
    12,267
    A shock is absolutely NOT the same thing as a spring. Engage brain before posting.
    The only difference between a shock and a strut is that a "strut" is a shock with a built-in spring perch. Hence our cars indeed have struts in the front, and shocks in the back.
    Furthermore, the common usage of "strut" means that the damper assy is a structural part of the suspension (i.e. necessary to locate the wheel/hub assy in the proper geometry), as in MacPherson strut. With our cars' 4-link suspension, our front struts are not necessarily structural, i.e. we don't have MacPherson struts. The B6 does, though.
  8. #6
    Jan 2006
    Southern Indiana
    4
    Thanks for the information. Does anyone have a recommendation for a replacement strut that will have similar ride quality to the factory struts? It's my wife's car and she's happy with stock performance. BTW, I'm learning tons about fixing the things that break on a lot of the Passats. Thanks for spreading the word.
  9. #7
    Retired PassatWorld Staff
    Aug 2001
    Mahtomedi MN USA
    46
    6,165
    I'm going to stir the pot here...
    Struts and shocks are not the same thing... and the position of the spring has nothing to do with what you call them.
    Both struts and shocks are DAMPERS.
    Shocks are dampers that ONLY control the chassis motion. Where as struts are also a locating member of the suspension. If you remove a strut, the wheel will move outside it's normal motion (meaning out of plane).
    The B5 (and B5.5) have shocks all the way around.
    You cannot assume that if it's a coil-over setup (which our front end is) that makes it a strut. MKIV's have struts... remove it, and the wheel falls off (reltatively speaking). On the Passat (not the PQ46) the wheel will maintain the same path if you remove the shock.
    A Mac Pherson strut is simply a specific design of a strut(which the MKIV's happen to use). To be a MacPherson strut, not only do you have to help hold the wheel in place, but you(you being the strut) also define the pivot axis of the wheel (steering). But wheel location is not specific to MacPhersons, it's specific to S.T.R.U.T.S.
    Make sense?
  10. #8
    Jan 2006
    Southern Indiana
    4
    Well, I don't feel so bad for being a little confused. If I understand correctly, I need to order, for my 1999 Passat GLX, front shocks, NOT struts? I still don't understand why www.autopartswarehouse.com lists both shocks and struts for the front of a 1999 V6 passat sedan.
  11. #9
    Grinding Gears...gone fishing! ScottPassat2.8's Avatar
    Feb 2005
    Staten Is. NY GLX2.8
    47
    22,620
    http://www.tirerack.com/suspension/S...lar=&brand=all
    strut assembly is whole assembly.
    shock is an insert for the strut.
    good for you?
  12. #10
    PassatWorld Staff
    Jun 2002
    Albuquerque, 1.8T A
    12,267
    Quote Originally Posted by pass-variant
    Make sense?
    Pot has been duly stirred. Now we can simmer properly. Thanks for the clarification - I was almost right...
  13. #11
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    53
    24,439
    Quote Originally Posted by Rusty
    I was thinking about it,but decided to let Rusty seem like he knew what he was talking about
    The Passat does not have inserts for the front. The shock is replaced as 1 peice.
    keldoc, if you want something close to the stock ride (when new),the KYB is a good choice.
  14. #12
    Jan 2006
    Southern Indiana
    4
    I think I know what I'm going to do. Take my car to the local shop, tell THEM to replace the existing part with a factory eqivalent, and throw whats left in the trunk! Then I'll get a good look and update this thread with my findings.
  15. #13
    May 2001
    Columbia, MD
    318
    Quote Originally Posted by keldoc
    I'm not sure I'd replace my current "struts" with a factory equivalent. For what seems to be about the same amount of money you should be able to get some aftermarkets shocks and springs, either here as part of a group buy or from any one of a number of web sites. This will give you a better ride and longer life for the same amount of money. Look and the H&R or Neuspeed springs and the Koni or Bilstein shocks.
    Thats just my opinion, I could be wrong...
    -K2
  16. #14
    Jan 2005
    Las Colinas, TX
    48
    2,293
    I wouldn't. You'll end up with crappy Monroe-Matic or Gabriel type shocks. Do youreself a favor and order KYB's or go to the stealership an get the OE replacements from Sachs ($$$). Then go to a shop and have them installed.
  17. #15
    Aug 2001
    Mahtomedi MN USA
    46
    6,165
    keldoc... please do a search... you can do much better than stock, in regards to handling... I like Eibach (natched dampers and springs, many other like Koni and FK........ stock is not the shit. Choose what you're preference is then compare.
  18. #16
    Dec 2005
    NY,NY
    198
    Quote Originally Posted by scottpassat2.8
    good for you?
    thanks scott i didnt even know tirerack sold part for suspension ..
  19. #17
    Mar 2006
    Yorkshire, England
    17
    FYI
    I have it on good authority (from my Quality Manager) that if you want the OE part buy a Monroe version - It the same part made on the same line and may be cheaper. (He used to work there)
  20. Remove Advertisements
Human Verification
