1.8T rear O2 sensor(How to replace?)
Results 1 to 5 of 5
    Nov 2003
    Zionsville, IN
    2
    I get DTC P1114 and P1118, so I removed the plug to check for heat element resistance and it is infinite (open)
    How do you take that sensor out? Do I have to remove the catalitic converter to get to it?
    Gus
    Nov 2000
    Bath ME//2000 1.8T Tiptronic
    2,249
    Try using a crowsfoot wrench attachment on your ratchet, if one
    of those 02 sockets are too tight for clearance. I used a 7/8"
    crowsfoot to do my pre-02 sensor. And when I was looking at the
    rear-02 sensor, I thought the crowsfoot would work pretty good there
    too. You'll have to use several extenions/swivels. A neat trick when
    trying to contort your position, is to use tape on the swivel areas to
    "form" to the shape/path your headed for.
    BTW, I recently had to replace my pre-02 sensor. And recently
    my MAF (P1128), which may have been related to my bad 02 sensor.
    HTH
    PassatWorld Staff
    Jun 2002
    Albuquerque, 1.8T A
    12,267
    Ditto on the crow's foot.
    You can get an O2 sensor socket over it, but there is not enough room to attach a ratchet or combi wrench to turn it. Crow's foot does the job.
  5. Remove Advertisements
  6. #4
    Nov 2003
    Zionsville, IN
    2
    Thank's, finally got it out and it's running with a new generic Bosch.
    The 7/8 crow's foot on a 3/8 ratchet was the first thing I tried but the sensor was on to tight.
    Some how I got a Ford wrench in there to get it loose, it had more leverage.
    the crow's foot worked well for installing the new sensor.
    This was a hard job for what should be a simple task but I'm happy the job got done.
  7. #5
    PassatWorld Staff
    Jun 2002
    Albuquerque, 1.8T A
    12,267
  8. Remove Advertisements
Human Verification
