Quick Links to Pertinent Posts:
Master parts purchase list.
http://www.passatworld.com/forums/a...r-1966-ford-f250-4x4-pick-up.html#post4353666
Well, the time has finally come for me to get my lazy butt out of the house and start working on my '66 Ford pick-up.
I've owned this truck for a number of years now and has been shuffled from one storage place to the next. It has been in my garage now for the last 4 years, but as usual, nothing has gotten done.
I've removed all the Passat parts that were piled up on the truck and now have decided to finally get it running.
By my rough calculations, it's been at least 20 years since this truck last ran. I've owned it for 11 years to be exact and I've never even attempted to try and make it run.
This truck is kinda rough right now, all I'm wanting to do is to get running so it goes down the road reliably.
Restoration will come at later date.
Vehicle details:
1966 F250 4x4 3/4 ton pick-up.
352 (5.7L) V8 'FE' motor. (208 hp from factory)
New process 435 4 speed manual transmission. (straight cut teeth on 1st and reverse gears)
New process 205 drive transfer case. (gear driven) (divorced from transmission)
4 wheel drum brakes.
Dana 44 closed knuckle front axle.
Dana 60 rear axle.
4.56 to 1 gear ratios.
Short history and notable notes:
During the 40's all the way up to the mid 70's, Ford, GM, and others shipped their '2wd' vehicles to other manufacturing facilities that actually converted them into '4wd' vehicles.
It wasn't until the late 70's when Ford and GM developed their own front axles, did they actually produce a '4wd' as part of the vehicle build process on the assembly line.
The Ford F250 model I own was only produced for model years 1965 and 1966, with the 4 wheel drive model being very rare. F100 '4wd' models were much more common.
I have only seen (3) 1966 F250 4x4's in my lifetime. I owned one when I was 18 years old. Sold it because I was stupid when I was 24. Now owning this one being my second. And the third vehicle was up for sale. (asking $30,000)
This is going to be interesting.
Exterior shots will be posted tomorrow.
Inside the cab.
Under the dash. :icon_eek: :thumbdown
Engine bay.
More wiring nightmares
Note: this page will be edited as soon as I get more pics uploaded to imgur.
Vehicle details:
Dana 60 rear axle.
Inside the cab.
Engine bay.
