Does using white vinegar strip wax?
NEWS
Results 1 to 12 of 12
    What time is Matlock on?
    Aug 2004
    over on NASIOC
    17,284
    Got some massive water spots on both windows and paint....if I use white vinegar to remove them, as discussed in another "wax on, wax off" thread, will it strip the wax/sealant I have? Don't wanna do that.....
    May 2006
    Abingdon, MD
    37
    20,458
    Maybe windows, never tried it on paint. don't know if I want to....
    B-5
    B-5 is offline
    The "Odd" one
    Jul 2005
    Northern VA
    40
    6,029
    Are you talking about hard water spots...that dont come off with claying. I was told the only way to get those out was to wetsand.
    Aug 2004
    over on NASIOC
    17,284
    Quote Originally Posted by VAGguy View Post
    Yeah, I'm skeptical too....thought I'd post it up and see if anyone has tried it. I DEFINITELY need it on my windows. This weekend is gonna be fun (oil/filter change with new pella extractor, polishing FMIC and piping, angle grinding some stuff on my lower front bumper , etc).
    Aug 2004
    over on NASIOC
    17,284
    Quote Originally Posted by B-5 View Post
    Yes...but they came off last time I claybar'd...I just have some more from watering the yard and don't feel like going through that grueling process again......
    BTW Pete....did you pick up that MKIII supercharged GTI
  7. #6
    Dec 2007
    Roseville, CA
    1,720
    Quote Originally Posted by swcrow17 View Post
    Water spots are usually an alkaline base. If it does not come off with washing then it is already through your wax and attached to the paint. Stripping the wax off is your least concern, it's already been compromised by the water spots. A vinegar solution is the acid required to neutralize the alkaline and eliminate the water spots and only works on light spotting, anything more than that may require more drastic measures like wet sanding, buffing and polishing.
  8. #7
    Redline
    May 2003
    Dyess AFB, Texas
    39
    23,183
    Clay barring shouldn't be that big a deal. You can also use #0000 steel wool and a car polish. You can also wetsand but if you thought claying the glass sucked, start sanding it and see how much fun you're having.
  9. #8
    Aug 2004
    over on NASIOC
    17,284
    Eh, I just associate clay bar'ing with the whole 8 step process, and I had to borrow a PC last time....time to pony up and buy one I suppose!Thanks!
  10. #9
    5th Gear
    Jun 2006
    Plano, TX
    26
    5,260
    Use a mix of Dawn Dish soap and clay bar to remove wax. Works magic!
  11. #10
    Redline
    May 2003
    Dyess AFB, Texas
    39
    23,183
    Why? Most of the time you can get by with claying and waxing. You only need to polish if you have some swirls or worse to remove.
  12. #11
    Confused
    Dec 2002
    State of Confusion
    5
    3,525
    Quote Originally Posted by dougmcp View Post
    x2. I used a 50/50 mix of distilled water and white vinegar to get rid of light spotting, but it does strip the wax. I only do the "acid wash" when I'm doing a full detail (polishing, etc), since I want all the wax off the car anyway. PM me if you want any advice!
    BTW: Claying also strips the wax, so I don't think there is anyway around reapplying your wax.
  13. #12
    Aug 2004
    over on NASIOC
    17,284
    Quote Originally Posted by quality_sound View Post
    Good point Q_S....I guess it's because I only associate claying and waxing WITH polishing cause I do them all at the same time 2x a year. I'll keep that in mind.....seeing as how I reeeeeeeeeeeeeally need to now that someone used my trunk as a coaster
  14. Remove Advertisements
