Door panel remove.
NEWS
Results 1 to 7 of 7
    Jan 2013
    Greece
    11
    Door panel remove.
    Hello,
    I have one B6 2.0tsi and i want to replace the door lock switch that is on the door panel of the drivers side.
    If someone knows how could i remove the door panel (without special vw tools), please help me.
    Thank you a lot
    Jan 2009
    LONDON, U.K.
    163
    This is the only door panel diagram I have:
    Nov 2009
    Brooklyn
    338
    any way to fix the outer door handle not opening the door wheneven though the inside door handle works fine. I can see the inside handle pull on the metal hook but nothing happens when I pull the outer handle, I watch the metal cable/hook that's in the rubber covering but I I don't know how to reconnect or see any issue or failure. This was fixed twice before and then after a while it stops opening from the outside again on the drivers door.
    Nov 2004
    Colorado
    72
    To get to the door lock mechanism you need to remove the carrier panel. Remove the door trim, then remove the outside door handle:
    ElsaWeb - Removal
    Then remove the carrier:
    ElsaWeb - Removal
    Jan 2013
    Greece
    11
    Doesn't open...
    Not Found
    The requested URL /doc/V.en-GB.K00590202/35357966/3 was not found on this server.
    Apache/2.2.22 (Ubuntu) Server at elsaweb.spaghetticoder.org Port 80
  7. #6
    Jan 2013
    Greece
    11
    I also found this but is not helpful...
  8. #7
    Jan 2013
    Greece
    11
    Finally it was easy...
    I have some pictures to show you...
  9. Remove Advertisements
