Perforated vinyl corners
NEWS
Results 1 to 10 of 10
    Jan 2011
    Austin, TX
    16
    I was going to get clear corners but decided to try this out. Looks sharp!
    Mar 2010
    PA
    422
    looks good, can you provide some more info?
    Jan 2009
    LONDON, U.K.
    174
    Quote Originally Posted by N715DP View Post
    Yeah, like a pix with the indicators on?
    Thanks!
    Jan 2011
    Austin, TX
    16
    3M makes a perforated black vinyl for the sign industry. Appears solid black until lit up. Really easy to apply due to the holes. No air pockets. I will get a pick with the indicator on as soon as I can.
    Jan 2011
    Austin, TX
    16
    Indicators On
  7. #6
    Jan 2009
    LONDON, U.K.
    174
    Looks good, will have a go. Did you wrap into the indicator housing?
    Is there a 3M catalogue number on the backing sheet of the vinyl you used? Then can try to find over here
  8. #7
    Jan 2011
    Austin, TX
    16
    Spec: 3M™ Dual-Color Film Series 3635-200
    I would check for legality. Since it peels off easily I'm not too worried.
  9. #8
    Jan 2009
    LONDON, U.K.
    174
    Seems good in your pix. Not a lot to lose anyways...
    Thanks for the quick reply!
    http://multimedia.3m.com/mws/mediawe...666eOqCOrrrrQ-
  10. #9
    Jan 2009
    LONDON, U.K.
    174
    Apparently the black version of 3635-200 is 3635-222 Still searching for UK supplier...
  11. #10
    Jan 2011
    Austin, TX
    16
    Try your local sign shop.
  12. Remove Advertisements
