Help with compass zones and speakers
NEWS
Results 1 to 4 of 4
    Mar 2011
    2
    Sorry if this has be posted before, but I am new to the forum.
    I bought a used 06 Passat V6 a few months ago from VW dealer, Certified. It did not have the owners manual and I have never gotten one as promised.
    Looking to change the compass zone? I live in Texas
    The volume "turns down" as I accelerate. How do I change this?
    Also, is there a download for the 06 Passat OM?
    Thanks in advance!
    Nov 2010
    Croatia
    68
    The volume shouldn't turn down? perhaps it's being drowned out.
    On your RCD unit (radio) go to Menu/Setup/Gala...this adjusts the strength of the auto volume which increases volume at higher speeds when surrounding noise increases.
    Mar 2011
    2
    Thanks Defex
    It worked! Now to find the compass zone.
    Mar 2010
    COLORADO
    59
    Depending upon where you are in texas you should be zone 6 or 7..i am in colorado and in zone 6 but that covers all the way up and down the us in that area then moves on to zone 7 moving east from there...so part of west texas falls under 6..give it a try.. When you set the zone (calibrate) you must drive in a complete circle.. So empty parking lots work best.. I drive 3x around just to make sure.. Mine is also a 2006 and gets screwed up some times so i have to reset it.
  6. Remove Advertisements
