Trouble code P2015
NEWS
Results 1 to 3 of 3
    Jun 2008
    Round Rock Texas
    25
    Trouble code P2015
    Heys Guys,
    Happy Holidays to all.
    On the way home tonight my check engine light came on. I stopped at an Auto Zone for a diagnostic. The only code that came up is P2015 but they did not have an exact match for an 09 Passat 2.0T.
    The car has 47K, just had the dealership change the oil on Thursday. Which I have done every 5K miles and it never missed a VW recommended scheduled maintenance.
    Anyone know what the code means and suggestions on how to fix or is this an issue only the dealership can handle.
    Thank you,
    Jack
    Jul 2003
    Toledo Ohio
    241
    Hated not seeing anyone helping you. This is what I found.
    Technical Service Bulletin Transaction No.: 2019394/1
    01-08-32 - DTC P2015 (2968) Stored in ECM Fault Memory (U.S. Only)
    Release date: Nov 21, 2008
    Condition:
    DTC will set with or without MIL ON
    DTC Description:
    P2015 (2968) Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Sporadic
    Technical Background:
    • Intake manifold tumble flaps sporadically stick.
    • Engine performance is not affected.
    http://forums.vwvortex.com/showthread.php?4333364
    Jun 2008
    Round Rock Texas
    25
    Thanks,
    I appreciate the help. Now, today the check engine light did not come on. I guess that would be the sporatically sticks.
    Ever happen to you? I'll do an additional search here and see if there has been any other threads I can gain some insight regarding. If not, I'll contact my local dealership and go from there.
    Again Thanks.
    Have a safe and Happy New Year,
    Jack
  5. Remove Advertisements
