Key/Ignition Problem
111K views 24 replies 15 participants last post by  RichardSEL
#1 · (Edited)
Key/Ignition Problem Update
So our 06 Passat has been giving us strange starting problems. It is like it will not recognize our key and not start or give the key back. It is very intermittent and if you wait a few minutes and play around with the key it eventually will start or give you the key.
A few weeks ago a code did come up saying something like Steering Lock Malfunction or something. It only gave that error once and I was planning on writing it down next time it did it.
I have an extended Warranty but for some reason this will not be covered and I can't imagine it a cheap fix. Does anyone have info on where I should start looking so I can fix the problem?
I just had the same problem with my 07 Passat. I took it to the VW dealer and they said it was the anti-theft module at the base of the steering column. Since the car is still under warrenty for another few thousand miles they covered it with no questions asked. They had to order a new module and in a few days they fixed it. While the part was on order I drove the car with basically no issues but the dealer warned me that one of these times the key fob might not be recognized then I'd be left to have it towed to the dealer. It's now fixed and everything works properly. As for the price of the module I'm not sure since it was covered under warrenty. Just make sure if you get if fixed that you give the dealer both sets of fobs so they can reprogram them to the new module code when replaced. Hope this helps and good luck!
Just got back from the Stealership with it fixed. $1125.62 out of my pocket:mad:
They replaced Steering Column w/ Lock Module and Comfort/Convenience Module (Immobilizer)
Part #'s if anyone wants to tackle this yourself
3C0-959-433-Q Control Unit
3C1-419-501-N Steering Column
They told me this was the 10th 06 Passat they have done this to this year. They even stock the parts to fix it.
I love this car and everything but if any one ask for an opinion on buying an 06 Passat I would walk away if it has not already had this fix done to it. Or make sure your extended warranty will cover the repair when it does fail:banghead:
Tim
#11 ·
Same
I just registered to say the same thing happened to our 2006 Passat. The intermittent no start thing started happening so we tried all the temporary fixes (waiting for the light to change color, moving the wheel, etc.) until the whole thing died. We took it to our local dealer here in Salt Lake, described the problem, told them we knew that this was a well documented issue, and that we had already talked with VWofA. They kindly fixed the problem even though the car was just out of warranty. I wanted to let people know that it looks like in at least some cases VW is making this right. Good luck to everyone that still has this problem.
#15 ·
i am located in ireland and have the same problem with the intermittent starting problem. when i contacted the local dealer they claimed that it was an isolated problem and that the repair would cost ÂŁ900+vat a total of ÂŁ1180. i got talking to one of the dealership mechanics and he said they were finding this problem more than twice a month. if anyone in the whole island of ireland can recommend a cheaper solution to this problem i would be very grateful. vw should be ashamed of themselves. a long time time vw fan lost.
#13 ·
steering electrical system, immobilizer
My 2006 Passat was giving problems to start. Diagnostic tests showed that the electrical system in the steering column/immobilizer was the problem. It appeared that the system was not recognizing my key. Finally it had to be towed as the problem got worse.
Nearly 1300 Cdn dollars later ..it was fixed.
I heard from one of the mechanics there that they have had a similar problems with quite a few Passats...\
After it was fixed the manager of the service dept of my VW called to say that he had called to VW to complain..and the money was refunded...Since my car had already 100,000 kms...I wasn't covered by warranty..
So...I got my money back and my faith in VW..lol
#14 ·
Same problem here, Where in Canada are you located? which vw dealer did you deal with? Thanx
#19 ·
re the immobilizer problem
Hi to all those who asked.
I am in Ontario.
I was at the dealer's today with my Dh' s jetta ...and was told that VW is planning a recall on this particular problem.
The first thing that started happening was that my right front driver's side door would not always close when I would click on my key. Then sometimes it would not open..just that door..I would have to open the back and reach over and open it manually from the back. Then the key problem in the ignition started. First it was not starting sometimes then it got worse...The key would get stuck too. (tip if key gets stuck put foot on brake and squeeze gear release button ..don't know if this applies to a manual)
Then the car would not start at all..
Thought my dealer had originally told me that the door problem was a latch problem...I have found since the immobilizer has been fixed...no more door latch problem.
Good luck...keep pounding on VW's door....
#20 ·
Marji
I am in Ontario.
Though my dealer had originally told me that the door problem was a latch problem...I have found since the immobilizer has been fixed...no more door latch problem.
#22 ·
i am the 2nd owner of a 07 passat wagon and I have this same issue. I called queensway VW who told me this part was already replaced back in 07 so they will not replace it again. Apparantly there is no fix for this issue, they are simply replacing bad parts with the same faulty parts. Their advise was to contact VW canada...i'm sure that will go far....
#23 ·
My '06 has now displayed this issue also. first instance was about 4 months ago and one key got stuck in the ignition and the car wouldn't cut off when i pressed the key. i eventually got the car to turn off but the key was still stuck in the ignition. after 20 minutes of attempting to get the key out, i just snatched it out of the ignition and i really thought that i broke something. I didn't have any icons pop up on my dashboard but the IMMOBILIZER ACTIVE warning was illuminated and my radio wouldn't go off. I had to pull the fuse out for the radio in order to turn that off.....i didn't want my battery to be dead the next morning. after being scared and not knowing what to do, i just let the car sit (i was at home) and didn't mess with it until the next morning. I used my second key and the car operated normally. no immobilizer active warning, the car started fine-all is good! (OR SO I THOUGHT!)
now 4 months later, the same thing is happening again. warning message, can't cut it off, key stuck in the ignition (MY SECOND KEY) and the radio won't turn off. I want to put a funny spin on this cause I am in the process of buying a 2011 Audi A5, and i guess my girl is jealous or punishing me for wanting to replace her. :icon_evil
i really don't want to go to the dealership, but i really think that i don't have any choice right now. unless, someone has replaced and reprogrammed this on their own.
HELP!!!!:cry:
#25 ·
https://sites.google.com/site/1810martin/b6-steering-fault
Havn't had this one on my '06 -- But do insert key to first position, wait for yellow steering wheel icon to go out; then to second position wait for red steering wheel light to go out, then start. Ever since reading about this fault in '09. I also check that steering wheel is in locked position when I park up. Dunno whether this helps avoid the fault or not, but got into the habit now.
No recall for this over here, but they've got the costs "down" to ÂŁ360 inc VAT at dealer now
