Electronic parking brake problem
NEWS
Page 1 of 2 12 LastLast
Results 1 to 30 of 38
Like Tree2Likes
Thread: Electronic parking brake problem
    Jul 2008
    SOUTH BAY, CA
    1,036
    Ive got a b5 and my dad has a b6(07 passat variant), but he's having problems with his e-brake. it would never engage and always gave a parking brake fault. so he took it in today for regular service, they said that its not the switch but they said they cant fix it without replacing some board, which happens to cost $1000 just in parts. so hes told them not to replace the board, and live without the parking brake. any ideas on anything else i could do to fix this problem without the massive bill?
    2nd Gear
    Jul 2007
    Slovakia, Kosice
    47
    645
    Quote Originally Posted by jhorkey View Post
    I got problem with e-brake last winter...The problem was that something was in the brake system and when it was cold, the e-brake didnt work. They solved it in VW, by cleaning it...
    I would go for the switch in the first place anyway. Had the same problem on my 07 variant, VW changed the switch and problem solved.
    Dec 2005
    Midlo, VA 04/S4
    2,486
    Blog Entries
    1
    I would think it would be covered under warranty...so who cares how much the parts are...or am I missing something?
    Jul 2008
    SOUTH BAY, CA
    1,036
    Apparently its not covered, and there is over 65k miles on the car so thats probably why its not being covered
  7. #6
    Dec 2005
    Midlo, VA 04/S4
    2,486
    Blog Entries
    1
    Wow...65k miles in under 2 years.
  8. #7
    2nd Gear
    Jul 2007
    Slovakia, Kosice
    47
    645
    Quote Originally Posted by MP33dave View Post
    I ve got 40K miles in one year Thanks to our "driving" job
  9. #8
    Dec 2005
    Midlo, VA 04/S4
    2,486
    Blog Entries
    1
    ugh...no thanks. I love to drive, but not like that.
  10. #9
    Jul 2008
    SOUTH BAY, CA
    1,036
    ya, he drives quite a bit. anyone have any ideas about this stupid parking brake fix?
  11. #10
    Aug 2006
    56
    Quote Originally Posted by KlausJ View Post
    Same here with my '06--same symptoms as the original poster--and VW replaced the switch under warranty two years ago. No problems ever since.
  12. #11
    Jul 2008
    SOUTH BAY, CA
    1,036
    the dealership ended up paying for the parts, we just had to pay the labor. so not too bad
  13. #12
    Sep 2006
    Ashburn, VA
    30
    8,987
    [rant about overengineering bullshittery deleted]
  14. #13
    Nov 2008
    KSA
    28
    29
    i had this problem... twice !!
    look
    i called the dealer and they told me how to fix it..
    unplug the battery for 10 minutes then plug it again then press the breaks for 35 seconds
    after that, while pressing the breaks press the e-breaks for 10 seconds..
    (( i think these are the right times ))
    then the cars computer will restart and the problem will be fixed !!
  15. #14
    Oct 2009
    Ireland
    49
    1
    Parking Brake
    fsnas,
    What a man !!
    I drive a Passat 2007, station wagon.
    Had parking brake - first intermittent problem, then totally out of service.
    Also system was making warning sound / bing ... even when car was driving.
    Local VW garage said they could not see me until 3 Nov - and would cost EUR 150 min to fix !!
    Searched the web .. found this forum ..
    Tried your reset formula.
    Brake now working perfect.
    Many thanks.
    Joe (from Ireland).
  16. #15
    Mar 2005
    Eastern Townships, Quebec
    175
    I think the '07 wagons came out in mid-'06 so that could be in 3 years depending on when he took delivery.
    Mine was delivered in Feb. '07 so it is a couple of months shy of 3 years, and I put 63k miles on it
  17. #16
    Nov 2009
    Cardiff, Wales. UK
    76
    1
    Further to Joe Reid and especially FSNAS, thanks for the info.
    I had the same problems. First, wouldn't disengage, Fault indicated,look in manual, but only found entry P16 under 'Caution', disengaing in neutral; that worked. But yesterday, wouldn't engage, had to park 'in 1st gear'. then found this site and followed FSNAS's cure and now all's back to normal. For good, hopefully.
    In view of the 65k mileage item, you might be interested to know that this is my fourth Passat (Estate Sport TDI), and my first one was the 1600cc 'L' estate, In-line engine but front-wheel drive. Over 8.5 years I did 228K business miles and NEVER had to put any oil in that engine!!! just regular servicing. The drum-brake shoes on the back wheels were the original factory fitted ones when I traded the car in. now that's good German engineering for you.
    Thanks again to you both,
    Bryan.
    Cardiff, Wales UK
  18. #17
    Feb 2010
    1
    Parking brake
    Had exactly the same problem with my 06.initially an intermittent problem--randomly the switch would stay lit up and warning light on dashboard with no brakes!!!
    Problem became permanent.
    Can't thank you guys enough!!!!Would very much like to shake your hand and thank you in person.
    By the way.I've had a problem with the e brake sticking on.Similar soution---disconnect battery for ashort time,then reconnect.
    Thanks again
    Quote Originally Posted by fsnas View Post
    look
  19. #18
    Feb 2010
    Chicago
    42
    very useful info.!
  20. #19
    Dec 2005
    NA
    132
    Quote Originally Posted by npdgroupindore View Post
    This is for all the forum members !
    As this is the new product launched and I just want to introduce this on forum
    specially for the electronics crazy forums.
    This, I got after the extensive research on internet and I think that they are good and affordable.
    Please have a look if it suits you. Thanks for the cooperation
    RC Helicopter Camera
    F^&$ this spammer
  21. #20
    Apr 2010
    Cork, Ireland
    82
    I have a 07 tdi passat with 250k kms on the clock..
  22. #21
    May 2010
    52
    Anyone thought of just pulling the fuse for the parking brake?
  23. #22
    Sep 2010
    Beds, UK
    5
    look
    Had the same problem with my 2006 2.0TDi estate a few weeks ago. Called the RAC man and he did something very similar to the above which fixed the problem...temporarily!
    Yesterday it happened again, hence my search for this forum. Fortunately I was at home and could use my wife's car (a 2001 Golf with a conventional handbrake) so was not stuck too badly.
    I am now waiting for the RAC again and this time I will watch more closely what he does.
    I hope this is not going to be a recurrent problem. From what I have read about the stupid e-brake on B6 Passats I am not so sure.
    The first time this problem happened was after a very heavy rainstorm. This time was after jet washing the wheels, so I wonder if water is getting in to the wiring or actuator.
    My last car was an '03 B5 TDI 130 estate which never gave me a day of trouble over 150k miles.
    You can see I am a fan of VWs, but this car may well change that...
  24. #23
    My e-brake button did fail again after a few months over 3 years, but the dealer did change it again on warranty since it has been replaced before. The driving distance is now 95.000 km.
  25. #24
    Sep 2010
    Beds, UK
    5
    Fault is happening more frequently now - refusing to engage or disengage. According to the previous owner the switch has been replaced before, but may be worth trying again. I guess it would be an easy DIY job?
  26. #25
    Aug 2007
    SGP
    114
    Hi, at how many km did you change your timing belt? TIA
    Quote Originally Posted by SARASON View Post
  27. #26
    Apr 2010
    Cork, Ireland
    82
    Quote Originally Posted by Black Beauty View Post
    Every 100k kms.
  28. #27
    Sep 2010
    Beds, UK
    5
    Fault is now permanent. Resetting makes no difference.
    I have set up a Facebook group on this subject. Please join and contribute.
    http://www.facebook.com/?ref=home#!/...72638656097468
  29. #28
    Oct 2010
    London
    19
    look
    OMG I just followed your instruction man, and you know what it worked, holy sh***t man ,you are the man,because you saved me alot of ££££.£££,and also my e-brakes failed working 1 o'clock in the morning I couldn't move, but here you go thanks to the man, and problem was solved in 15 min. Thanks man.!
    seguro1980 likes this.
  30. #29
    Dec 2010
    1
    Fixing those pesky e brake buttons
    has happened to me three times - 2006 Passat Turbo diesel - second time button was 'replaced' by dealer - happened again today - each time during wet and humid conditions.
    Quicker fix than fsnas
    1. Unlock car
    2. Unplug negative terminal keeping keys out of the way (so you don’t accidentally press anything) and leave unplugged for 10 seconds or so.
    3. Reconnect
    4. Lock car
    5. Unlock car
    6. Insert key to light up dash but don’t start car
    7. Remove key
    8. Lock car for 10 seconds
    9. Unlock car
    10. Insert key but don’t power up
    11. Unlock park brake with foot on brake – YAY!!!
    12. Power up
    13. Warning lights may be (anti skid control, tyre pressure, steering etc)
    14. A quick drive round the block should correct the above if not into VW for resetting.
  31. #30
    Dec 2006
    Brisbane Australia
    30
    I am on my 3rd switch. You can apply/release handbrake (if it's just the switch)
    apply: use auto-hold to drive around and put it in park and turn off the car, handbrake will apply
    release: start the car, put on your seatbelt, grab D or R, and when you press the accelerator, the handbrake will release
    good luck!
  32. Remove Advertisements
There are currently 5 users browsing this thread. (0 members and 5 guests)
