Regular gas vs premium in 06 Passat 2.0T
NEWS
Results 1 to 14 of 14
    Oct 2006
    PHOENIX, AZ
    40
    Can the 2.0T in my 06 Passat be run on regular gas all the time without damaging the engine? I understand that it would decrease the performance, and possibly the MPG some.
    Tim in AridZona
    Dec 2005
    Bethlehem, WV
    2,281
    Although the ECU will theoretically sense the reduced octane and retard the timing in an attempt to avoid detonation, DO NOT RUN YOUR B6 ON REGULAR GAS. I believe VW requires a minium octane of 89 and the "recommended" octane is 91. For the savings of a few cents per gallon, you are risking serious potential engine damage and the big-time voiding of your VW warranty; that's just plain foolish.
    PS: Welcome to PW.
    nm+
    nm+ is offline
    5th Gear
    Jan 2006
    Minneapolis
    5,404
    from another thread:
    If you can't afford premium (or sythetic oil), you can't afford a passat.
    Run 91, or please sell your car and buy a camry.
    Oct 2004
    42
    Quote Originally Posted by nm+ View Post
    interesting, seems accurate, might use that myself
    bottom line
    if you are out of gas and the station doesnt have 91 octane fine fill it up with regular, you should notice the difference if you pay attention and for sure your engine WILL notice the difference,
    the economics dont work out, I tried it myself once and the MPG went down but more importantly the car didnt drive as well and driving well is what a Passat is all about (we sure dont buy them for reliability or dealer satisfaction)
    NEVER skimp on oil quality or tires
    6th Gear
    Jun 2006
    Bklyn NYC
    9,407
    WOW .... just bought a new car and your worrying about spending $1.40 more on a fill up .....cheapos......
  7. #6
    May 2006
    Abingdon, MD
    37
    20,576
    using a tank here and there out of necessity will not hurt the car. Just use 91+ whenever possible. Do not substitute for monetary reasons, only for lack of 91+ availability in the area.
  8. #7
    6th Gear
    Jun 2006
    Bklyn NYC
    9,407
    this is the UNITED STATES OF AMERICA not MEXICO what gas station doesnt have 92/93oct...
  9. #8
    nm+
    nm+ is offline
    5th Gear
    Jan 2006
    Minneapolis
    5,404
    Quote Originally Posted by bksuperman View Post
    The one in the middle of the great salt desert in Utah
    Also many states only have 91. California being the big one
  10. #9
    Dec 2005
    Bethlehem, WV
    2,281
    [There is no place to get 89/91] in the middle of the great salt desert in Utah
    The Desert is only 80 miles wide; don't be a dunderhead: fill up before you make the crossing.
  11. #10
    Oct 2006
    PHOENIX, AZ
    40
    Good advice from all - I will use nothing but Premium in my 06 Passat!
    Tim in AridZona
  12. #11
    nm+
    nm+ is offline
    5th Gear
    Jan 2006
    Minneapolis
    5,404
    Quote Originally Posted by GreggD View Post
    I'm saying its there, not that i use it.
  13. #12
    Overdrive
    Jan 2006
    Fargo ND
    30
    11,880
    I can only get 92 at holiday and the local fleet supply place, which are both 30 miles away and I dont there often during the summer so I have to use 91. I can also get 100 oct down by the race track(BIR). Traveling have seen some states that highest they have is 89 at the pumps.
  14. #13
    Sep 2004
    Buford, GA
    1,738
    Quote Originally Posted by passatzona View Post
    Tim in AridZona
    Good decision!!! Enjoy your new Ride!
  15. #14
    May 2000
    Saskatoon SK Canada
    59
    177
    regular gas is okay
    seems everyone is an expert; so here goes
    the engine will require a certain octane rating at steady driving conditions and a higher octane rating under hard acceleration conditions... Does everyone here drive their car at full acceleration all the time? doubt it...
    common sense suggests that the factory octane rating is required especially under hard acceleration conditions, if you do it all the time yeah will have to run the high octane gas, if all you do is cruise at highway speeds, i would doubt you will get the benefit of the premium grade....
    i have the same problem with my motorcycle, it calls for premium gas, when i am riding in city stop and go traffic even the premium is not be enough when the weather is hot, as i can here the pinging, but on the highway the bike is just loofing along
    i now have 180,000 on my b5, i have driven 70,000 this last year covering about 1500 per week, and 1000 of that is 2 x 500 trips, i am only runnning regular and getting over 40 mpg do it....
    so establish a baseline with premium, then switch to a lower grade and check for fuel economy, and pinging, the newer moronic ssytem may be so good you never hear the rattle at accel, but if you do that would be an indication...
  16. Remove Advertisements
