The oil pressure drops to 0 then you have no oil circulating in your engine which means if you dont stop and turn off the motor you can blow it up. It will seize. Oil pressure would be the first thing I would check.
your oil pickup tube might be clogged (happened to mine and the PO have done a ******* fix to clean it up)
Related Threads
Volkswagen Passat Forum
3M posts
158.6K members
Since 2002
