Hi all, have just bought my 2nd B5. It's a 98 1.8t Manual, 200,000kms.
Overall is a very good car after a good day of cleaning. Just have a few issues with how it drives:
1: Seems a bit low on power, I think I'll replace the DV. Have cleaned MAF sensor and throttle body, any other tips?
2: Steering wheel clunks at low speed when moved from side to side, also seems to grab a little when turning at higher speeds, and when going over bumps. Any Ideas?
1) It's a rather large car with a 150hp engine. Yeah, it's a bit low on power. Chipping the ECU can make a dramatic difference.
2) Tie Rod Ends. By this point, your car is probably due to have the TRE's and Control Arms replaced.
3) Stuck thermostat.
4) Bulb.
In addition, make sure all the maintenance is up to date. If you don't know the last time the timing belt was changed, change it. It needs to be done every 100k km or so. (Along with the t-belt tensioner, idler, waterpump and accessory belts.)
Regarding your flickering headlight: check the connector that plugs on to the bulb. They tend to get loose, thus making a poor connection, which then gets hot. The heat from the bulb only makes matters worse. You may have to replace a crimp on connector or the entire socket.
Your manual should feel quicker than a tip. I have 2 (well 3 but that one's an Audi) AEB powered B5 wagons, one tip and one stick. Tip feels more sluggish for sure.
Try new plugs and air filter, and install a boost gauge. You should get about 7 psi at WOT and idle (no a/c) at about 20"Hg. Deceleration in gear you should pull 22-24"Hg.
If your boost is low, you will need to check the turbo and charge piping. If your vac isn't as strong as it should be, you may have issues with valves or rings, and need a compression/leak-down test.
Steering clunk sounds like it's coming from up around battery area, checked steering rack bolts and they are tight.
Checked out headlight, the whole inner has broken and is just floating around inside the housing, will have to replace the headlight.
Put in a new air filter, will do oil/filter, power steering flush, DV and Spark Plugs this week.
4. Inside the headlight there are plastic ball joints and a rubber sleeve in the internals mounting, these often become disconnected and can be reconnected.
Cheers for that. I think I've traced my lack of power down to a faulty Wastegate Actuator.
Related Threads
Volkswagen Passat Forum
3M posts
158.6K members
Since 2002
