Originally Posted by
ajshoe
did u find a solution to this misfire problem ??? I have a 2001 1.8T awm auto passat with rebuilt engine. My symptoms are it runs perfect until the engine idles a long period (engine warm - leave car on and return and the engine is running rough). misfiring ?? and giving it gas will increase rpms but runs rough. If I turn off engine and restart - runs perfect again. Can drive it anywhere and it runs perfect. Stop car and put it into park - leave car and return and it sometimes will be running rough. Code it throws is misfiring on cylinder 2 and 3. Has new iridium plugs, new maf, new battery, new coil packs (swap them - same error). fuel pressure is 50 psi, doesn't leak anything, everything on car works like new. anyone have a suggestion ???
UPDATE: seems that only goes into misfiring mode when put in park, leave car, return and it is running rough. Only way to get it run correctly is restarting engine.
