Please double-check my V6 cam chain timing
1 reading
6.5K views 6 replies 5 participants last post by  V6er
Hello folks, Can you please take a look at the photos of my 1999 V6 AHA cam chain timing & tell me if it looks correct to you?
In a short story: I lost the timing belt & damaged some intake valves on the car. I removed both cylinder heads & replaced them with remanufactured head from Cylinder Heads International. The rebuilt heads did not come with the timing chains or cam chain adjusters so I had to remove the cams & set up the chain roller spacing & install it all back on the head. I put everything back together & now the engine starts right up and doesn't skip or anything but it is making a ticking noise which I think is coming from the passenger side head. I have gotten the engine up to operating temp. & the noise does not go away. One morning I started it in 35 degree outside temps. & it did not tick at all for a few minutes but as the oil temp warmed up the ticking sound was back.
So at this point I am concerned that either my cam chain timing is off a roller or my cam chain tension adjuster is not working correctly. I notice when I turn the engine over by hand I do get a little oil or oil bubbles coming out of where the piston on the CCT fits inside the housing of the CCT. Perhaps a bad seal & oil pressure leaking by?
If you guys could take at look at the number of rollers I have between the cam timing marks & let me know or any other advice you could give would be great!
Thank you
I took the photos with the engine at TDC. That red mark on the timing chain is from some work the previous owner had done.
Hello Humble, I scanned the car this evening & there are no timing faults. No engine faults at all.
Hello GSO_Passater, Yes I had rotated the engine by hand quite a number of times by hand before I took the photos. Every time I count the rollers it looks like 15.5 or 16 rollers, depending on how you look at it. If the timing chain timing is correct then I think it must be the cam chain tensioner. Which leads me to another question...
Has anyone ever re-sealed a cam chain tensioner? Are there o-rings or square cut o-rings inside that could be replaced or do you have to buy the whole assembly?
Thanks,
I had a pair apart a few months back to replace the chain guides.
There are no seals, just the clearance between the CCT pistons and the body providing the seal.
If you had no noise when the oil was cold then I would guess they are worn and losing oil pressure.
How about trying a heavier weight oil?
