Low temp gauge and no heat even after thermostat replaced?
NEWS
Results 1 to 5 of 5
    Feb 2011
    Great Midwest
    4
    Long time listener, first time caller here...
    My car (2001.5 Passat wagon, 1.8T) just had its 105k service (new water pump, timing belt, tensioners) last week at the dealership. I also asked them to replace the thermostat and flush the coolant, as the temperature gauge had read low all winter and the heat didn't really work, suggesting the thermostat was stuck open.
    I've driven the car over 100 miles since, and the temp gauge still reads low sometimes. It's close to 190F after ~10min of highway driving in 60F weather, and sometimes gets to 190F after ~15min of city driving. But this morning it stayed at the low end of the scale after 10min of highway driving in 30F weather.
    Does this still sound like a thermostat problem? Or do you suppose the car's computer still thinks it hasn't been replaced, and maybe disconnecting the battery for 5 minutes (to reset all the "learned" parameters to default settings) might work?
    Super (Charged) Moderator, Grinding Gears...gone fishing! ScottPassat2.8's Avatar
    Feb 2005
    Staten Is. NY GLX2.8
    45
    22,618
    it could be the heater core, you can feel the line to see if they are both hot.
    if you're singing the "I ain't got no heat" blues...
    if they are it could be the temperature sensor.
    Quick Link MASTER at your service.Forum Moderator.
    Feb 2011
    Great Midwest
    4
    Quote Originally Posted by ScottPassat2.8 View Post
    Thanks for the quick reply!
    But if it was a clogged heater core, wouldn't that be independent of the temp gauge?
    And because the temp gauge seems to fluctuate inversely with driving speed in colder weather, wouldn't that rule out the sensor as well?
    Feb 2005
    45
    22,618
    check the core lines, if they are hot then it is not the core.
    It could be the thermostat also.
    I put "could be" for a reason
    I am not there to check the car so you have to and these are the things I would check.
    6th Gear
    Feb 2007
    Lehigh County, Pa.
    59
    9,816
    It's not the computer, and I doubt it's the heater core. Matter of fact, it sounds exactly like a bad thermostat. For what you probably paid the dealer for the TB job, I wouldn't waste any thought on it. Take it back and have them deal with it.
  7. Remove Advertisements
