Battery and EPC light
NEWS
Results 1 to 15 of 15
    May 2006
    Kansas City
    244
    I pulled my car into the garage last night, no problems. i go to leave for work this morning and it won't start. The car cranks and will continue to crank (never letting it go for more than 3-5 secs at a time). Then, i noticed the batter light was on but i didn't figure it was the battery since it would crank fine and also the battery isn't that old. I let it sit for a while and then went back a little while later. I turned the key over and let all the lights come on and go off, but the battery light and the EPC light were still on. I tried cranking again, same thing only this time the oil pressure light comes on and STOP! flashed on the dash. I have had this light before but it was only when sharp cornering and i was low on oil due to a leak, but never just sitting. Any ideas on what it could be? Is the oil pressure light just a result of and electrical issue due to EPC light? Any ideas would help, thanks.
    May 2006
    Kansas City
    244
    Oil pressure light is probably a separate issue, checked the oil and it was low. Put in oil and the light didn't come back on when i retried to start.
    May 2006
    Kansas City
    244
    I was able to bring a code reader home tonight.
    P0174 - System too lean (bank 2)
    P0171 - System too lean (bank 1)
    P0491 - Secondary Air Injection System insufficient flow (bank 1)
    P0421 (This code was already on there before the issues)
    Would any of these lead to the car not starting? When i turn the key over and let all the lights on the dash come on, the EPC, CEL and battery light still stay on. While I am turning it over, the car just sputters and the battery light blinks. Any ideas?
    Thanks
    May 2006
    Kansas City
    244
    Any ideas?
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    59
    10,047
    The lean warning might contribute to starting issues, if it was bad enough. The SAIP and catalyst problems wouldn't.
  7. #6
    May 2006
    Kansas City
    244
    I tried starting again, still no start. However, the oil pressure light kept coming on saying to stop. I checked the oil and there was plenty of oil in it. I did all this in my garage, and no smell of gas at all. I am going to check the fuel pump and relay this afternoon. I realize at this point it could be several different things so from reading, I guess I will start there. If anyone has any other ideas, feel free to throw them out there.
  8. #7
    Jan 2003
    Waterford CT USA
    26,891
    Blog Entries
    4
    year? V6 or 1.8T? mileage? what kind of maintenance has been done on it in the past?
  9. #8
    May 2006
    Kansas City
    244
    02 GLX 4motion v6 w/ 145k. Maintenance is pretty basic. Did the timing belt and all at about 100k.
  10. #9
    Jan 2010
    Finland
    25
    180
    Ok here it comes.
    Question number one: Did you only drive the car from the driveway inside tha garage ?
    For the lights. The battery ligh has nothing to do whit battery, it abaut the altenator. It the charging voltage drops too low, the light comes on to notify the driver that theres fault on the altenator.
    The oilpreasure comes on becose of the crank. If the crankshaft is spinning, so is the oilpump. But, since the starter cant spinn the engine / oilpump fast enough, the oilpreasure is under the minium -> Light goes on.
    So so far theres nothing wrong whit the car.
    If awnser for the first question is Yeas, it might also explain the lean warning.
    If you run the engine only for short time, not allowing it to cut off the riched fuel mixture, it can couse thing called "Glued valve". When you turn the engine off, the riched fuel mixture can wonder freely inside the engine, inside the valve guide, where it starts forming drops. When the fuel drops dry off, it "glues" the valve to the valve guide, leaving the valve open just a litlebit.
    In result, the engine wount crank, and the starting sound litle bit like there would be no combustion on the engine.
    How to fix it ? Get your self a battery charger, and just crank - crank - crank and crank. Neede to keep on cranking my v6 for abaut 15mins before it fired up.
  11. #10
    May 2006
    Kansas City
    244
    Yes, we just pulled it into the garage. I needed the garage to do some woodworking, so i pulled it out and the next day just pulled it back in. It was running rich before the issues, which is why i was surprised there was no fuel smell while having it in the garage.
    Also, isn't there a pretty good chance of burning up the starter trying to start the car like this?
  12. #11
    Jan 2010
    Finland
    25
    180
    Quote Originally Posted by dsmith4031 View Post
    Nope, you dont keep cranking it 15mins on row, 15sec tops at per time and then let it cool a bit. -> repeat.
    Also, litle tapping for the cylinder heads whit rubber hammer can sometimes help a bit.
  13. #12
    May 2006
    Kansas City
    244
    I took out the spare tire cover and took off the round panel under that with 3 screws. Checked the voltage with a multimeter and there was no power to it. So, I was going to move on to the fuel pump relay. Does anyone have any tips/links to replacing this? Thanks
  14. #13
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,845
    The battery and EPC are just from the car not running. Usually it's just a flooded engine when this happens, but you would smell gas. Let us know once you check the relay and fuses.
  15. #14
    Jan 2010
    Finland
    25
    180
    The pump doesent run always.
    If the fuel line is empty, the pump runs untill it manages to build up the preasure on the fuel system, and then it turns off. When the engine is started, it starts to run again...
  16. #15
    May 2006
    Kansas City
    244
    Relay worked. I took it out and took my amp/speaker power and ground wire to test it. So, I got a bottle of heet and a few more gallons of gas. Also, it was finally sunny and above freezing for the first time in several days so I parked it outside in the sun and jumped it from my truck. The combo of all of this and several attempts it reluctantly started.
  17. Remove Advertisements
