Anyone recharge their air conditioner?
NEWS
Results 1 to 24 of 24
Like Tree2Likes
  • 1 Post By High Gear
  • 1 Post By Attofarad
Thread: Anyone recharge their air conditioner?
    Nov 2004
    CT.
    147
    The one in my 99 only works ok below 85 degrees. After that it is not effective. How hard is it to recharge the system? I did a search and came up with nothing.
    2nd Gear
    Aug 2007
    Denver,Pa
    41
    853
    Quote Originally Posted by High Gear View Post
    Very easy if you have the right equiptment.
    2nd Gear
    Feb 2010
    NEPA
    526
    They sell kits now that come in one bottle, find the low side and fill.
    Something like this...
    http://shop.advanceautoparts.com/web...T|GRP2004A____
    Nov 2004
    CT.
    147
    Quote Originally Posted by ThaWaxShop View Post
    What do you mean by the low side?
    2nd Gear
    Feb 2010
    NEPA
    526
    There are two ports on your ac lines, one is a high side and the other the low side, sometimes identified by red (high) and blue (low) caps. They have schrader valves to measure pressure and/or fill the system
  7. #6
    May 2010
    3
    I'm in the same boat, can some one post a diagram or a better description of the location of the low pressure port. I have spent 2 hours looking. I'm sure it is right in front of my eyes.
    2004 VW Passat 1.8T
  8. #7
    6th Gear
    Feb 2007
    Lehigh County, Pa.
    59
    9,354
    Note that attempting to "top up" the A/C system, or check the fill by pressure, is not recommended. This commonly overfills the system, and causes a loss of cooling efficiency. Proper technique is to evacuate the system and fill with a measured weight of coolant.
  9. #8
    2nd Gear
    Feb 2010
    NEPA
    526
    Yes that is the proper way but the equipment to do so is pricey compared to the top off, and releasing it into the atmospehere is illegal. Shops usuall charge a good premium to do so. Truth is if you ac isn't working right you have a leak somewhere
  10. #9
    May 2010
    3
    Thank you. I appreciate the guidance and am aware of how it is normally (and should be done) but just want to check the pressure before making the decision to get it fixed professionally or just put it out to pasture. I'm an engineer by trade and probably just can't see it becuase I don't have a diagram. I've had that issue before; don't know where it is till I know where it is . Appreciate any help anyone can give on pointing me towards the low pressure port.
  11. #10
    Confused
    Dec 2002
    State of Confusion
    4
    3,511
    It's behind the 2nd firewall next to the battery. There are two caps (high and low). The ports are different sizes, so there's little chance of putting the meter on the wrong one.
  12. #11
    May 2010
    3
    Thank you, found em rather quickly once I got the cowl off. It was indeed under the optimal pressure; put in some leak stop with dye so if it drops again in the next two weeks it ought to be real easy for me to spot the problem and determine if I'm in need of professional intervention.
  13. #12
    Confused
    Dec 2002
    State of Confusion
    4
    3,511
    Good luck!
  14. #13
    Nov 2004
    CT.
    147
    Could it just be that the car is eleven years old?
  15. #14
    2nd Gear
    Feb 2010
    NEPA
    526
    See the system is sealed, and since its sealed the only way to lose refrigerant is a leak. If your pressure is low it might need refrigerant but keep in mind why the refrigerant was lost in the first place (bad o rings in the system, small leak somewhere). It could also be a bad relay or low side pressure switch. Can you hear the clutch engage? My car is also 11 years old with ice cold flowing ac
  16. #15
    Nov 2004
    CT.
    147
    Since I do get cold air on cooler day, wouldn't the cluch be engaging?
  17. #16
    2nd Gear
    Feb 2010
    NEPA
    526
    Maybe its your fan clutch. There is a second fan on the driver side of the car attached to a clutch that might not be working. Turn on the ac and let it go and see if that fan is spinning the way it should. In more heat it might not be working right and not flowing the air needed to condence the coolant back to a liquid
  18. #17
    May 2010
    Maine
    14
    Be careful using stop leak it is a band aid and is a temporary fix.
  19. #18
    Nov 2004
    CT.
    147
    Good point. I'll check that first. I did store the car for a year and started it every month. It worked great before it was stored. I just have to see if it engages. If not, I'm sure that would be it. I'll post back.
  20. #19
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    50
    21,726
    Almost all a/c systems leak a little. It's not unusual to have to top them off after 5 years. I had great luck with the DIY kits from Autozone. Just make sure you don't overfill. I've seen several people just dump a can in without reading pressures.
  21. #20
    Feb 2010
    AR
    67
    I have an 06 armada...it blew cold until last year I noticed It was not ice cold anymore. I bought one of the kits and filled it til the gauge said it was good. It stayed cold all summer...and still cold so far this year.
    My Passat is kind of in the same boat now, the reason why I read this topic. So I think I may go buy another kit and try it on my 03 Passat. It's cold but doesn't seem ice cold like I think it should be.
  22. #21
    Nov 2004
    CT.
    147
    I did check and the fan and it is working. So, it must just be low on refrigerant. I called a friend thats a mechanic. He will the proper top-off for $50. Thats $30 more than a can of "do it yourself". Maybe it's worth it. I just know that I need to do this before it gets real hot.
    Roger Smith likes this.
  23. #22
    Jun 2006
    San Jose, CA
    1,432
    I have the low/high side gauges, which you can get for ~$30-$40 from Harbor Freight. For my wife's QX4, the pressure readings made perfect sense, and cooling was fixed by adding R134a. For my Passat, the readings were a bit cryptic. I added a left over 1/2 can (6oz) to the 2001 Passat a year ago, and the cooling was a bit better, but it was never that bad anyway.
  24. #23
    Nov 2009
    Houston
    159
    No cold air in my car, I took off the red cap and heard a light hiss. Is that a leak or does that just happen when you take the cap off
  25. #24
    (insert title) Moderator Steve in Chicago's Avatar
    Jul 2008
    Chicago
    51
    13,624
    Sounds like your valve core is leaking. It should hold pressure with or without the plastic cover/cap on.
  26. Remove Advertisements
