I took it to the stealership to get the alternator and some vac. lines replaced all under an extended warranty. They informed me that both valve cover gaskets and right side cam adjuster gaskets are leaking. They quoted me $700 to get this fixed. By no means am I a mechanic or close to but I am trying to get this stuff done as cheap as possible so I am going to try to tackle this myself. I have done extensive research on here and I am wondering if the PCV suction pump might be the cause?? In reading some topics if I check the PCV suction pump I might as well replace it.
1. Is ECS tuning the place to get the suction pump or is a Local autozone/advance a better bet??
2. Is the gasket job to difficult to try??
3. Any special tools needed for the gasket job????
thanks everyone!!
LinkBack URL
About LinkBacks
Golf
Passat Wagon
Sedan
Bessy
