Rear Door Panel Removal
NEWS
Results 1 to 18 of 18
    May 2006
    Abingdon, MD
    37
    20,378
    Somebody asked for a write up on the rear door panel removal on the B5/5.5
    NOTE: �� Place scraping blade - 2 - or similar tool between screwdriver and door trim to avoid damage on door trim
    �� Insert screwdriver (max. 5 mm wide) into hole on underside of inside door handle - arrow - , rotate
    and pry out panel - 1 -.
    NOTE: �� Inside door handle - 3 - is bolted to door trim and can only be removed
    when door trim is removed.
    �� Remove bolts - 1 - and - 2 -.
    �� Remove bolt - 1 -.
    �� Unclip door trim at the sides using Pliers 3392.(or get a general panel popper/trim removal tool)
    �� Lift door trim upward out of window recess.
    �� Pull cable - 1 - out of guide - 2 - in - direction of arrow - and disengage.
    �� Disconnect harness connector - 3 -.
    �� Pull off window recess seal - 1 - from door trim and insert in window recess.
    NOTE: �� Replace clips before installing door trim.
    Last edited by JayTheSnork; 02-24-2010 at 11:54 AM. Reason: moved to the proper forum.
    Feb 2010
    va
    31
    yeah thanks, I cant get that stupid door handle off for the life of me and im starting to nip up my leather and i cracked the plastic a little bit . Eh And i also just read a thread saying that the freaking speakers are damn pop riveted in....WHAT KIND OF SHIT IS THAT SON?????
    I love dubs but pop rivited speakers USE Skrews DAMN
    Thanks anyways.
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    59
    10,049
    Quote Originally Posted by dublove View Post
    If you read the instructions carefully, the handle is held by four screws; two from the front and two from the back. You have to take the door panel off to get to the rear screws.
    Rivets, yeah, kinda dumb. Probably cooked up how much assembly labor they'd save vs. additional repair labor, and seasoned with more secure mounting. It's all a formula.
    May 2006
    Abingdon, MD
    37
    20,378
    you don't even need to remove the handle, just the two big screws from the front side. Leave the handle attached to the door card.
    Jan 2010
    NYC
    112
    how about the front doors
    i need to replace my speakers
  7. #6
    Dec 2007
    Tamarac, FL
    34
    As VAGguy said, handle can stay on ..
    BUT .. if you're fixing up your loose fabric or broken leather and need to remove the handle, there are 2 screws that come off from the other side of the panel, if you don't and pull too hard trying to get the handle off, you'll just wind up ripping the screws out and breaking the threads.
  8. #7
    Jan 2003
    Waterford CT USA
    26,893
    Blog Entries
    4
    Quote Originally Posted by BigBlack315 View Post
    in the information base forum, there is a post related to replacing the window regulators. it shows how to remove the front door interior panels.
    it is available in the index that is a sticky post at the top of the page.
  9. #8
    Jan 2007
    Empire State
    28
    9,944
    you will also need c4 explosive to remove the last screw.
  10. #9
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    59
    10,049
    Basically the same, except for the driver's door handle/switch panel. You have to pry out the inner part where your fingers rest, to release the switch panel. Then IIRC there's a couple of screws behind it.
  11. #10
    Feb 2010
    Central NJ '99 1.8T
    81
    Thanks - this will help fix that back window issue I have!
  12. #11
    Jul 2008
    Chicago
    51
    14,586
    The rivets holding the speakers don't loosen up over time and start buzzing like sheet metal screws sometimes do. Rivets also probably cut the installation time at the factory. Removing the rivets is simple if you have a drill and know the technique.
  13. #12
    Mar 2010
    6
    I'm having a window issue and just discovered these instructions.
    Any chance that you have higher resolution images? The pics are so fuzzy.
    Anyway, I'm on step 2 (I think it's image 350) and have a question.
    How do you remove the outdoor trim?
  14. #13
    May 2006
    Abingdon, MD
    37
    20,378
    go to step three. The second pic is for removing the screws in the door handle. remove the torx screw in the bottom of the door and then pop the door panel around the perimeter starting at the bottom, then lift up and off the door.
  15. #14
    Mar 2010
    6
    Quote Originally Posted by VAGguy View Post
    Haha. I thought the instructions meant remove the door trim on the "exterior" of the car.
    Ok, these are weird looking screws. What sort of screw driver do I need to remove them?
  16. #15
    Dec 2001
    Shelton, CT USA
    58
    1,401
    Quote Originally Posted by gate4exec View Post
    Torx, T-25 I believe.
  17. #16
  18. #17
    Jul 2010
    2
    rear door panel - window off track
    OK -so all of the post above have been helpful - however I still cannot remove the metal plate from the door to access the window track. Is there a trick or a special tool? I removed all the screws, disconnected the electronics and door latch - it seems loose, but cannot pull it away or move too much. I am afraid to damage it - nearly deforming the metal plate in an attempt to separate.
    Any thoughts on this would greatly be appreciated... thank you.
  19. #18
    I'm Urlik's Hero
    Jul 2004
    UK
    13
    9,785
    If you've removed all the bolts (they're a sort of copper in colour) then all that's left to do is unbolt the door lock and waggle the window runner/guide out of the hole.
  20. Remove Advertisements
