Yellow Sludge Found on Oil Cap
NEWS
Results 1 to 4 of 4
    Sep 2009
    29
    99 V6 passat with 119,500 miles. Been running great. Go to change oil and removing oil cap I see a lot of yellow sludge built up. I've read that it could be due to not allowing the engine to fully warm up and taking lots of short trips especially in the winter time, but is there any additional specific notes about the passat? Any seals that probably need to be checked / looked at?
    Jan 2008
    14
    yellow crud
    I found the same yellow sludge when I changed out my pcv valve. Let me know if you find out what it is and whether it has any significance.
    5th Gear
    Mar 2006
    montreal, quebec
    6,248
    sister has that yellow slime under the cap and loosing coolant somewhere in her mk4 jetta
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,834
    It's normal with cold weather/short trips.
  6. Remove Advertisements
