p1392 and p1626
NEWS
Results 1 to 5 of 5
Thread: p1392 and p1626
    Dec 2009
    Tulsa, OK
    103
    p1392 and p1626
    99 passat GLS V6 2.8l 5 speed manual. These codes come on as a pair at the same time. Sometimes a p0300 and other 3 misfire codes (forgot which ones but it don't really matter). Sometimes it takes a lil drive for these codes to come on but usually they pop up right at engine start. What is the problem? Why do I have transmission control unit code if I have a manual transmission? Which side is bank 1 and which side is bank 2 if I have to replace the camshaft position sensor? And last question: What symptoms would I have if the engine had a misplaced timing belt by a tooth, or/and a misplaced cam chain by a tooth? I recently did the valve job on this engine. First engine I actually rebuilt myself, don't have mu ch experience, so I think i might have misplaced something there, but the car runs really good. Lotsa power and good gas mileage. Any help?
    Dec 2009
    Tulsa, OK
    103
    No clues
    Jun 2008
    Neenah, WI
    30
    227
    17800/P1392/005010 - Camshaft Position Sensor Bank 2 (G163): Open Short to Plus
    Possible Symptoms
    * Power Loss at Full Throttle
    * High Fuel Consumption
    * Bad Emission Values
    Possible Causes
    * Wiring between Engine Control Module and Camshaft Position Sensor Bank 2 (G163) faulty
    * Power Supply/Ground Wiring from/to Camshaft Position Sensor Bank 2 (G163) faulty
    * Camshaft Position Sensor Bank 2 (G163) faulty
    * Engine Control Module faulty
    Possible Solutions
    * Check Wiring between Engine Control Module and Camshaft Position Sensor Bank 2 (G163)
    * Check Camshaft Position Sensor Bank 2 (G163)
    * Check Engine Control Module
    P1626 Data Bus Powertrain missing message from Transm.Contr.
    ... sorry not sure what this one means... could it be that a problem with your ECU is causing this one too?
    Feb 2010
    Chicago
    193
    you shouldnt have a TCM (Tranmission Control Module) if your car is a 5 speed. Recode the ECM so that it won't look for it.
    Dec 2009
    Tulsa, OK
    103
    It was a misplaced cam chain by a tooth.
  7. Remove Advertisements
