anyone know the location of Side impact sensor
NEWS
Results 1 to 4 of 4
    Oct 2006
    San Diego
    6
    Otherwise known as the Drivers side crash sensor? didn't see it in the b-piller area, is it hidden in the door??? on a side note, anyone know if an airbag fault can be reset with the ebay vagcom cables? Had a Drivers side sensor fault cleared it up, and two weeks later its back...
    2nd Gear
    Dec 2003
    Pittsburgh
    24
    702
    I've never heard of a side impact sensor throwing a fault, but anyways here you go..Good Luck
    Oct 2006
    San Diego
    6
    wow... all the way down there under the seat.. ok.. thanks, saved a lot of searching... yup.. that was the code i got drivers side, side impact sensor.. maby it just the wiring down there.. have to go check it out.. thanks again..
    anyone know if the ebay vagcom will clear an airbag issue??? don't feel like driving the 1 1/2 hours to my buddies house again...
    Dec 2007
    connecticut
    335
    I have a good driver side airbag sensor FS. You could try wiggling the plug or checking grounds. It's a pain but it could save you buying the sensor. Will sell cheap.
  6. Remove Advertisements
