Passanger Side back Window seems off track?
NEWS
Results 1 to 5 of 5
    Jul 2009
    14
    The rear passanger window on my 1999 passat 1.8T does not work, when I bought it the previous owner said it fell off its track? Also the rear passager side speaker does not work so I figured kill to passat problems in 1 session. How do I take of the door panel and put the window back on track, and replace or reconnect speaker wires.
    Oct 2008
    Grand Rapids, MI
    12
    There is a "how to" thread in the information base forum:
    DIY: The Permanent Rear Window Regulator Clip Fix (aka: the Cabinet Knob Trick)
    There is a link in that "how to" on door panel removal.
    4th Gear
    Oct 2005
    Galesville Maryland
    3,266
    Quote Originally Posted by nedc View Post
    Good procedure, but get the real pin. It's cheaper than a cabinet knob anyway.
    Jan 2003
    Waterford CT USA
    26,875
    Blog Entries
    4
    most often, the two-piece pin is lying in the bottom of the door.
    4th Gear
    Oct 2005
    Galesville Maryland
    3,266
    Even if you don't reuse it, it's a good idea to remove it so that it doesn't clog the door drain holes. This also applies to the bits of broken clips from broken front regulators.
  7. Remove Advertisements
