V6 Clutch Replacement?
NEWS
Results 1 to 11 of 11
    Jun 2002
    OH/FL
    82
    I've done EXTENSIVE searching, and I cannot find a good DIY how-to on changing the clutch on a B5 Passat 2.8L V6. My car specifically is a 2000 ATQ V6 with a 5spd, FWD, and a little over 93k miles. Clutch was slipping for awhile, but finally got so weak it hardly can pull itself up to 30mph.
    Also, looking for GOOD parts...Sachs through ECStuning, I've heard. New dual-mass flywheel probably.
    Thanks for everyone's help!
    Jul 2008
    Chicago
    51
    14,654
    Quote Originally Posted by zeitgeist57 View Post
    Yea, you'll need a new flywheel also.
    Also look into South Bend Clutch.
    http://www.dxdracingclutches.com/
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,873
    Although mine is a Tiptronic, removing the trans will be very similar in the procedure and tools needed. You can read the thread/see pics from the 2nd page on and see what was involved. The manual trans should be quite a bit easier (and lighter). The FWD is also much lighter and easier to work around. Here is the link to my trans drop:
    Failing torque converter.
    Jun 2002
    OH/FL
    82
    I noticed South Bend, but the listings are only for 1.8T...not the 2.8 V6??? Do they have the right application, and should I therefore just call them?
    Jul 2008
    Chicago
    51
    14,654
    Good question. I got a stage 3 clutch from them for my 1.8t, but I don't know what they have for the V6. Call em' up and ask.
  7. #6
    Jun 2002
    OH/FL
    82
    If South Bend doesn't have an application for the V6, then I'll just go ECS Tuning for FW and clutch kit.
    Thanks for the info so far...please post more if anyone has more to add. I'm going to St. Louis for business all this week, but I'd like to have parts ordered so I can get going on this next weekend when I'm back at home.
  8. #7
    Lefties have rights, too!
    Apr 2001
    NY or MA???
    57
    15,626
    AWE sells the Southbend clutch kit so you should be OK.
    http://www.awe-tuning.com/pages/shar...L=clutchnfw30v
  9. #8
    Jan 2003
    Waterford CT USA
    26,935
    Blog Entries
    4
    use a stock clutch for the V6. there's no sense in putting extra $ into it - unless you have a supercharger.
  10. #9
    Jul 2006
    New Berlin, WI
    48
    1,406
    True that.
    Believe it or not the stock clutch can take a fair amount of abuse.
    Unless you're s/c'd I wouldn't spend the extra $$.
    A word to the wise. A higher stage clutch doesn't last any longer, matter of fact it will get less lifetime miles than a factory clutch.
  11. #10
    Jun 2002
    OH/FL
    82
    Thanks for the updates. Any recommended sites/sources for stock clutch?
    I got back from St. Louis without getting the parts ordered...will need to move forward soon...
  12. #11
    Sep 2006
    plano/waco, Tx
    26
    13,315
    Blog Entries
    5
    agreed.
    and as to what pz said, it will yes, be more or less the same as the automatic trans removal and reinstall, but it will be extreemly easier as the manual will weigh atleast 50 pounds less.
  13. Remove Advertisements
