Got a 2001 Passat with a screwy electrical problem. Right rear running light doesn't work, 2nd filament illuminates fine when brake is pressed.
- All other lights work fine, so it can't be the fuse.
- When I move the right bulb to the left side, both filaments work normally.
- When I move the left bulb to the right side, only the brake filament works properly. So, it's not the bulb.
- With the lights on and the bulb removed from the right rear light housing, I get current on the voltmeter when I apply the prongs to the leads in the running light socket.
Any ideas?
Should I just suck it up and replace the entire assembly?
LinkBack URL
About LinkBacks
1999 Volkswagen Passat
