Error codes: P1136, and P1565
NEWS
Results 1 to 4 of 4
    Nov 2008
    30
    My check engine light came on so i got the codes read.
    P1136, Long term fuel trim add. Fuel B1 system too lean.
    P1565, Idle speed control throttle position lower limit not obtained.
    Now what do I do to fix them?
    Vac leak?
    Jul 2008
    GARLAND, TX
    39
    52
    if this is a 1.8t you have a vacuum leak and the throttle body is dirty.
    Nov 2008
    30
    Forgot to add that detail..
    The throttle body is clean... on one side.. havent checked the other side.. and i mean clean.. and I figured it was a vac leak...
    Time for
    Thanks.
    Nov 2008
    30
    I still haven't found the issue. Talk about a thread from the dead. The engine is AEB and i replaced the two vacuum lines that i could find and cleaned the throttle body. But still have a Check Engine. I'm going to have to get it read again and see if its the same.
  6. Remove Advertisements
