2003 1.8T no Spark
NEWS
Results 1 to 13 of 13
    Dec 2005
    Corpus Christi, TX
    51
    65
    2003 1.8T no Spark
    I have a 2003 Passat 1.8T that doesn't start. The fuel pump works, it turns over fine but there is no spark.
    I have done some searching and checked the crank speed sensor, cam sensor, connectors and all the fuses. I think I am down to the ECU. Does anyone have any other suggestions? I bought the car in non-running condition with no history. Thanks in advance.
    Overdrive
    Jan 2006
    Fargo ND
    30
    11,880
    How did you come to no spark, just wondering.
    Dec 2005
    Corpus Christi, TX
    51
    65
    I did it the old fashioned way, removed one spark plug and attached the coil pack, turned the engine with the starter while someone checked for spark...nothing.
    4th Gear
    Nov 2005
    Arizona
    3,559
    Did you try scanning the car with a VAG-COM? If you can communicate with the ECU, then I doubt it's bad.
    Dec 2005
    Corpus Christi, TX
    51
    65
    My friend has my VAG-COM cable and he is 2 hours away. I used an Actron scanner but there were no codes stored. I will try to get my VAGCOM over the next few days. I guess regardless of scanner type, the fact that there was communication with the ECU should indicate a working ECU...correct?
  7. #6
    4th Gear
    Jun 2004
    mary land
    3,844
    I recently replaced the speed(crank) sensor on my 03 1.8T because of the same problem. Make sure of the problem before getting yourself another ECU.
  8. #7
    Dec 2005
    Corpus Christi, TX
    51
    65
    Did your crank speed sensor fail the resistance test in the manual, or did it test good but was bad anyway?
  9. #8
    4th Gear
    Jun 2004
    mary land
    3,844
    Mine was on and off kinda problem, starts fine one day then no spark the next. Luckily mine threw a code so it was easier fix for me.
  10. #9
    Dec 2005
    Corpus Christi, TX
    51
    65
    Happy Thanksgiving and thanks for your response. I changed the crank speed sensor yesterday but it still doesn't start. My sensor was in bad shape with some of the plastic missing so now I am thinking there could be some internal damage. There was also some metal filings stuck on the sensor's magnet.
    I got a good deal on an ECU so that will be next. Thanks again for everyone's help. I will report what I eventually find.
    Mark
  11. #10
    5th Gear
    Apr 2001
    puget sound
    49
    6,736
    Quote Originally Posted by IriePassat View Post
    Not to state the obvious, but you did ground it?
    It will not spark unless grounded.
    Holding a coilpack attached to a plug in middair=nothing.
  12. #11
    Dec 2005
    Corpus Christi, TX
    51
    65
    I did ground the spark plug. Although it sounds obvious, I am sure someone has done it before. Thanks for the input.
  13. #12
    Overdrive
    Jan 2006
    Fargo ND
    30
    11,880
    I would Vag it to make sure you are getting input from the other engine sensors.
  14. #13
    Dec 2005
    Corpus Christi, TX
    51
    65
    My friend is sending back my VAGCOM cable in the mail today. I should have it by Monday, I also have an ECU on the way.
  15. Remove Advertisements
