How To Remove The Gear Stick Gaiter
NEWS
Results 1 to 8 of 8
    Jul 2006
    Sunderland U.K.
    33
    35
    I own a B5.5 2002 2.0 SE the Gaiter around to gear stick is cracked and looks an eye sore so I bought a new one from Mr Gaiter on Ebay and I'm really struggling to fit it. I first uncliped the plastic trim around the base to reveal the underneath of the gear knob and just cannot see how it comes off.
    Super (Charged) Moderator, Grinding Gears...gone fishing! ScottPassat2.8's Avatar
    Feb 2005
    Staten Is. NY GLX2.8
    45
    22,618
    4th Gear
    Oct 2005
    Galesville Maryland
    3,266
    Quote Originally Posted by FARINA-VW View Post
    Twist it.
    Sep 2004
    Kent, UK.
    307
    Don't you have to break/cut the clamp on B5.5,s?
    4th Gear
    Apr 2007
    Knoxville,TN
    31
    3,557
    yep. either one. Then use a hose clamp to put back on
  7. #6
    Jul 2006
    Sunderland U.K.
    33
    35
    [QUOTE=TwoManyPassats;1788829]Twist it.[/QUOTE
    I have tried to uncsrew but will not budge
  8. #7
    Jan 2005
    Lutterworth, Leics,UK
    190
    Like as been posted above, on a B5.5 the knob is held on by a crimped clip.
    Lift the gaiter to see it.
    Use a large screwdriver it expand the crimped bit carefully and you can reuse it.
  9. #8
    Jul 2006
    Sunderland U.K.
    33
    35
    I carefully unpicked thread on the gaitor enough to get it over the gearknob and re-sewed with a fine needle I found this less hastle it was a bit fiddly to get it back in the plastic clip but it now looks great
  10. Remove Advertisements
