air bag removal
NEWS
Results 1 to 10 of 10
Thread: air bag removal
    Mar 2006
    37
    air bag removal
    anyone got any detailed instruction's on how to remove an airbag from my 2001 passat?
    Lefties have rights, too!
    Apr 2001
    NY or MA???
    57
    15,622
    Check the info forum?
    IIRC, there is a DIY for intalling a R32 steering wheel which describes how to remove the airbag. It's not that hard just remember to disconnect the battery first. There are two clips which hold it in. They can be released by inserting a small screw driver into the two holes in the back of the steering wheel. The wheel has to be tuened before you can access the holes.
    Mar 2006
    37
    hi mate thankyou for replying ive used the search but i cant seem to find it
    Overdrive
    Jan 2006
    Fargo ND
    30
    11,880
    If you look at the back of the wheel the are two holes at 3 and 9 and you stick a screw driver in to release the bag, really hard the first couple times, but I can do one in like 15 seconds now;
    I'm Urlik's Hero
    Jul 2004
    UK
    12
    9,785
  7. #6
    Mar 2006
    37
    cheers guy's
  8. #7
    Mar 2006
    37
    i tried for hours and still couldnt manage to get the airbag off im sick of it now
  9. #8
    Overdrive
    Jan 2006
    Fargo ND
    30
    11,880
    Quote Originally Posted by bmw222000 View Post
    Keep trying, its a feel you have to get use to, once you get it, its a feel you will never forget.
  10. #9
    2nd Gear
    Aug 2005
    Frankfort, Michigan
    590
    For anyone who is doing this for the first time, I'll toss in my .02
    It's kinda like the first time you......well, nevermind
    The steering wheel has to be turned 1/4 turn to access the holes on the back. Look at the backside of the steering wheel, into those 2 holes.
    There is a metal wire (looks like a piece of coat-hanger wire) laying across a metal surface inside the steering wheel, which you can see if you look in the hole. Simply slide that metal wire towards the center hub of the steering wheel, and you will hear/feel a POP as it releases the spring on that side of the wheel. Do the same on the other side, and the airbag will come off.
    I did it my first time in about 45 seconds, it's REAL easy.
    Ben
  11. #10
    Sep 2012
    Chambersburg, PA
    51
    I just replaced the turn signal switch today. What a pain in the a$$!! Most difficult part was removing the airbag. I must have spent the better part of 90 minutes trying to figure out how to release the springs. Good as new now though.
  12. Remove Advertisements
