How to check Brake Fluid
NEWS
Results 1 to 5 of 5
    Aug 2006
    West Virginia
    22
    I just got a 2002 Passat GLX V6 4Motion a few months ago. I had the STOP Brake warning light come on a few times. Now, I'm trying to find out how to check the fluid level. Also, what type of fluid I need to top it off.
    Thanks
    2nd Gear
    May 2002
    Portland OR USA
    805
    With the hood open you will find your reservoir between the 1st and 2nd firewall, driver's side. It is marked as to maximum and minimum levels. The fluid should be changed out every couple of years - so if it hasn't been done before now would be a good time.
    Normally the only reason you would need to add fluid between brake flushes is because your brake pads have worn.
    The recommended fluid is DOT 4. Valvoline's SYN Power (fully synthetic)brake fluid is dual rated - DOT 3 and DOT 4. You can find it many auto supply stores such as AutoZone for a reasonable price.
    Dec 2004
    00 V6 variant/06 4-m
    61
    2,139
    Quote Originally Posted by WvUpassat02
    Thanks
    THE LIGHTCAN COME ON FOR OTHER REASONS BESIDES BRAKE FLUID
    Aug 2006
    West Virginia
    22
    I just had the dealership do a brake check about a week before the light started coming on. What else could the light be coming on for??
    Arj
    Arj is offline
    4th Gear
    Oct 2001
    Plano TX USA
    2,574
    I recently flushed my brake fluid and, when all was done, started up the car and got the STOP light in the dash. I then remembered that I had overfilled the fluid reservoir, so I drained some of it back out and then the light went off. Hasn't come on again since.
    But I too wonder how people check their fluid levels. When using Valvoline Syn Power, which is a light color, I can't really tell for sure what the level is by looking at the markings on the side of the reservoir. My car is a 2001.5 and has the two siphon ports on the top of the reservoir, besides the refill hole. Is it possible to remove the refill screen and just look inside? I wasn't sure how it can be removed and didn't want to force (and break) it.
  7. Remove Advertisements
