Rotten eggs/sulfur smell inside the car
NEWS
Results 1 to 13 of 13
    2nd Gear
    Dec 2004
    Gateshead, UK
    41
    910
    I've just started to notice a slight smell of rotten eggs/sulfur inside the car, ususally when I'm starting, parking up or stationary. I have a 1999 1.8T which has done 110,000 miles.
    I've done a search. My first reaction was the cat may be going bad , but performance wise it seems lively as ever. Its also been smog checked recently as part of an annual inspection and passed.
    However, I'm wondering whether the spark plugs were gapped properly at the last service just after inspection by my local garage (who I have now disowned due to other issues!). To be honest, I'm frightened to check spark plugs, as they are well recessed, and I'm not sure whether my socket will fit. I don't even know what the correct spark plug gap should be, and even whether badly gap plugs would lead to unburned fuel . I seem to be averaging 27 MPG (US) at the moment through 50/50 city highway conditions
    I'm also wondering whether the smell is coming from bacteria in the AC system. I must admit, the cabin filter looks as if its been in the car since new. Perhaps this is why the AC never gets really cold, and I have used it almost every time i've been out somewhere.
    I've also heard that this small could be caused by a leaking vacuum hose, but then I wouldn't know where to look.
    If anyone could guide me in the right direction and offer advice, I would be really greatful. Thanks!
    2nd Gear
    Dec 2003
    Galt's Gulch, USA
    43
    894
    Replace your cabin filter. Could also be road kill. Squirrels smell pretty ripe a few days after hitting them.
    Oct 2002
    Conyers,GA (Atlanta)
    49
    5,599
    Roll down your windows and open your sunroof when you fart. It works wonders.
    Sorry, couldn't resist.The sulfur/rotten egg smell would seem to indicate fuel as you suspect, and pretty much would rule out road kill I would think, that has a special smell all its own. Sorry I can't be much help, but free bump though.
    5th Gear
    Jan 2005
    NJ
    6,597
    Nov 2000
    Bath ME//2000 1.8T Tiptronic
    2,249
    It's fairly typical for the catalytic converter to smell sulphurous (rotten
    eggs) when it's clogged /going bad. Especially if you notice the smell after
    leaning into the throttle.
  7. #6
    Mar 2003
    boston ma usa
    36
    2,311
    sulfer/egg smell doesnt mean your cat is going bad, it happens from gasoline with high sulfer content, try switching brands of gas.
  8. #7
    Nov 2000
    2,249
    Quote Originally Posted by 1.8tbeout
    Yes it is a typical sign of a bad cat from my experience. All I'm saying is
    that it COULD be going bad, not that it is. It could of course be fuel too,
    or 100 other things.
    You shouldn't discount someone elses opinion based soley on your
    own experiences.
  9. #8
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,827
    You really need to figure out if it is from the inside of the car or from the exhaust.
    If you notice it just after starting, it is probably in the a/c system. If you notice it after hard driving, it is sulfer in the gas.
  10. #9
    Mar 2003
    boston ma usa
    36
    2,311
    Quote Originally Posted by Colin
    own experiences.
    i wasnt discounting your opinion, sorry if it sounded that way, the smell usually comes from high sulfer content in certain brands of gasoline. sulfer is a by product from crude oil, the more refined the gasoline, the lower the sulfer contnet. if you have no check engine light on try switching to better gas. if the smell is acompanied by a cel it probably means your cat is glowing red hot dumping unburned gas from your exhaust. you will be able to feel your exhaust coming from the tail pipe is burning hot.
  11. #10
    Nov 2000
    2,249
    Thank you, I think I overreacted. I apologize if I sounded like a penis.
  12. #11
    Apr 2005
    miami, fl
    35
    62
    it could be just a simple fix like the battery
    that also smells like rotten eggs when is bad and leaking
    check your battery
  13. #12
    Nov 2003
    New England
    1,191
    Quote Originally Posted by coolbep
    check your battery
    I agree, don't rule this one out.
  14. #13
    My intake has Emphysema R36Dreams's Avatar
    Apr 2005
    Manassas, VA
    42
    7,589
    Blog Entries
    3
    This happened on my Dakota. Same smell, and as you, more power. It did end up being my cat. The core actually broke loose inside. Of course, I couldn't hear it rattle around but when the mech took it off he showed it to me and it was like shaking a coke can with the tab inside.
    If the core breaks loose like mine did, there's less airflow restriction, so it feels more "peppy".
    Don't HUFF it, but put your nose by your tailpipe after a cold start or just reach under the car and tap (lightly) your cat with a rubber mallet when it's cold.
    My two cents.
  15. Remove Advertisements
