"engine" smell coming out of vents.
NEWS
Page 1 of 2 12 LastLast
Results 1 to 30 of 55
    Oct 2005
    san diego, 03/V6/5sp wagon
    39
    1,964
    I get a bit of engine smell when I drive.
    Even the 'cabin air control' on the off position, there is still a bit of breeze coming out of the vents, and that s where the smell comes from.
    is that the cabin filter?
    May 2002
    LI NY
    322
    Take a look at the filter. It could be moldy. I change mine twice a year to keep it fresh.
    2nd Gear
    Apr 2005
    Auburn Hills, MI
    37
    930
    By "engine" smell do you possibly mean burning oil smell? it's possibly some oil leaks that are burning off on the manifold when you drive. It's a pretty common issue.
    Feb 2004
    newcastle,DE
    2,330
    ^^^ that will most likely be your cam seals.
    2nd Gear
    Jun 2005
    Los Angeles, CA
    501
    valve cover gasket
  7. #6
    2nd Gear
    Nov 2000
    Rochester, NY
    694
    Year, mileage, engine, maintenance history...?
    My vote's for PCV issues (especially if an early B5).
  8. #7
    Oct 2005
    39
    1,964
    i own a B5.5 (built 09/02) v6 wagon, 5sp, 49000 miles, i m the second owner; first was a lease so I m pretty sure it was somewhat maintained.
    I tried troubleshooting a bit today:
    -when the AC is on, the smell isn't too bad.
    -when the ventilation is on "cabin recycle" the smell isn t so bad either.
    -the worse is when the air comes from the outside (engine?), without the AC on (ventilation only)
    I'll have the cam seals changed in 10K miles, wile doing the TB job, hopefully they ll do it under warranty.
    until then, will a new cabin filter resolve the smell issue?
  9. #8
    Oct 2005
    39
    1,964
    the smell comes right away though, right upon starting the car pretty much. if it was oil burning, wouldn t it take a while before it started to smell?
  10. #9
    2nd Gear
    Oct 2003
    SoFLA '00 Variant 1.8T 5spd
    773
    You should have it checked out right away. To stop the smell until you do, push the recirculate button (this will also stop the "breeze" you describe, which is normal in all automobiles). Just don't do this and pretend the problem's solved!
  11. #10
    Oct 2005
    39
    1,964
    ok, I ll take it in asap, thanks for the advice.
  12. #11
    2nd Gear
    Nov 2000
    Rochester, NY
    694
    Quote Originally Posted by katone
    i own a B5.5 (built 09/02) v6 wagon, 5sp, 49000 miles, i m the second owner; ...I'll have the cam seals changed in 10K miles, wile doing the TB job, hopefully they ll do it under warranty.
    I think cam seals (or almost anything that would be causing the problem) would be covered under the 4/50 bumper to bumper warranty. Why wait 10k miles? You're barely still under the B2B warranty now, so in another 10k you'd be resorting to the PT warranty (which only goes to 60k, and does that even apply for the 2nd owner?), which might or might not cover it depending on exactly what's wrong...(unless you have some sort of extended coverage?).
    In any case I wouldn't just cover it up by replacing the cabin filter. If you really need to as a temporary measure, probably best to go with the more expensive carbon type.
  13. #12
    Oct 2005
    39
    1,964
    thanks, I already scheduled at VW.
    btw, what does PCV mean?
  14. #13
    2nd Gear
    Nov 2000
    Rochester, NY
    694
    PCV = Positive Crankcase Ventilation
  15. #14
    Oct 2005
    39
    1,964
    is PCV 'related' to the cam seals at all?
    Sorry if I m asking many questions, i m just willing to learn and know a bit more about this issue before talking directly to the VW dealer. it might save some time and money (and might also get my car fixed correctly)..
  16. #15
    2nd Gear
    Nov 2000
    Rochester, NY
    694
    Yes, my understanding is if the PCV system is clogged up, it can allow pressure to build up in the crankcase and blow out the cam seals.
  17. #16
    Oct 2005
    39
    1,964
    my bet is that accessing the PCV to clean all that up must not be that easy.. correct?
  18. #17
    2nd Gear
    Nov 2000
    Rochester, NY
    694
    Someone who knows the V6 would be better than me to answer that. For the 1.8T it's not too bad, but that's partly due to the writeups and pics in the info forum post. I don't see the same info available there for the V6, so that even makes me wonder that it may not really be the same issue with that engine.
  19. #18
    2nd Gear
    Jun 2005
    Los Angeles, CA
    501
    piece of cake...
    here's an awesome writeup by ashman78:
    V6 PCV system replacement (with pics)
  20. #19
    PassatWorld Staff
    Jun 2002
    Albuquerque, 1.8T A
    12,267
    In addition to all of the above, it could also be a cracked dipstick tube causing your oil smell.
  21. #20
    Oct 2005
    39
    1,964
    Great, thanks for the DIY link.
    1- it seems that the PCV issue would NOT be taken care off under warranty (normal tear), while the cam seal would.. am I right?
    2- could it be that ONLY the PCV is damaged (and create the oil smell in the cabin)?
    if so, is there any way to check is cam seals are affected?
    if so again, maybe I should replace the PCV before taking it to the dealership and save some $$.//.
    3- I have CEL on (not blinking), code "P0441: Evaporative Emission Control System Incorrect Purge Flow" (yes, my gas cap is tight..).
    Could this be related at all with the PCV/cam seal issue?
  22. #21
    2nd Gear
    Nov 2000
    Rochester, NY
    694
    1 - Not sure why it wouldn't be covered under the B2B as long as something is actually failed/broken.
    2 - Yes, it could be only a PCV problem. That was the case for me.
    3 - Seems could definitely be related, but someone who knows the codes should confirm or deny.
    Thing is with the dealer it's tough to try to point them at what's wrong. They don't like to be told their job, they assume you're like most customers and couldn't possibly know what you're talking about, or whatever the reason. At least you also have the CEL to point at that they must fix.
  23. #22
    Oct 2005
    39
    1,964
    I visually inspected the engine, PCV, looked around for leaks. everything seems clean.
    I'll bring it to the shop tomorrow morning and report.
  24. #23
    4th Gear
    Aug 2003
    Centreville VA
    34
    2,718
    Its not a leak your looking for
    its cloged with CRAP
    that makes extra pressure in the passanger side valve cover area causing it to seep oil
  25. #24
    4th Gear
    Aug 2003
    Centreville VA
    34
    2,718
  26. #25
    2nd Gear
    Jun 2005
    Los Angeles, CA
    501
    Quote Originally Posted by crash893
    dude, that's really bad man... what's the mileage when you changed that PCV? mine wasn't clogged like that, but still it was so dirty.
  27. #26
    Oct 2005
    39
    1,964
    wow.
    what causes the PCV to get clogged like that, is that 'normal' tear??
  28. #27
    Oct 2005
    39
    1,964
    is there anyway to find out if the cam seals are in bad shape just by doing a 'visual inspection'?
  29. #28
    2nd Gear
    Sep 2004
    Twinsburg, OH
    38
    696
    Not to semi-hijack, but are there any write-ups around for replacing a cam seal &/or cam chain tensioner? I've been looking & haven't found one yet.
  30. #29
    6th Gear
    Feb 2001
    Hoover, AL
    36
    9,108
    Quote Originally Posted by StewPidass0
    Check Audiworld, I think I saw a decent one over there recently (2.8?)
  31. #30
    4th Gear
    Aug 2003
    Centreville VA
    34
    2,718
    when you find it let me know ill added to the index
  32. Remove Advertisements
