Can you tell if the timing belt has been replaced?
NEWS
Results 1 to 12 of 12
    Mar 2005
    17
    My wife and I both drive Passats, mine is a 99 v6 (100k miles) and hers is a 00 v6 wagon (65k miles). We bought both of these used so I don't have a full maintenance history and I am worried that the timing belts might not have been replaced in either one. The wagon was bought as certified preowned with 49,500 miles from a VW dealer, but mine was bought from a non-VW dealer with 94,000 miles. Is there any way to look and see if the belt has been replaced, or do I have to go and have it done as preventative maintenance?
    Feb 2005
    Palm Harbor,FL
    32
    267
    As far as I know the V6 in passats don't have timing belts they have chains therefore don't require as much maintenance. They should be good for about 200K Miles if not more.
    Jun 2005
    ATL
    32
    1,385
    not true, I have a 99 V6 and the timing belt (irrelevant of whether belt or chain) is due to be replaced by the books at 105k. Timing belts are very crucial so I can't imagine that they are built to stretch, etc. be cause if they are just marginally off, pistons will start hitting valves at hig speeds and expensive things start to happen. Get it changed at 105k.
    JEM
    JEM is offline
    Jan 2003
    Houston TX
    1,359
    blind leading the blind
    Dec 2004
    00 V6 variant/06 4-m
    61
    2,139
    do you feel lucky, punk.................a mechanic can check the belt but its not a definate,it may have been on for some time and is hard to tell,...you can try and go to a VwoA dealer and ask him to run the vin# and maybe youll get lucky and find out if it was serviced at a VW dealer,otherwise its like russian roullette............anyway you made one good choice by buying one CPO vechicle,....as on the other ,like clint (dirty harry) eastwood said do you feel lucky..also only the VR6 had a chain,.....the V-6 30V 2.8 engine is an (interferance type) lose your belt,lose your valves,pistons,engine$$$$$$ etc.it has a timing belt
  7. #6
    Dec 2004
    61
    2,139
    also would you want to wait and take a chance for another few thousnad miles?,spend a thousnd now or about 4-5000$ later if it goes,dont forget the water pump and related items along with the belt.good luck, i know,i have two passat V-6 ,one w/53,000 the other w/74,000 miles..........accoding to the english/german red lettered sticker in the engine compartment on thenradiator shroud it says"75,000"miles....................go from there
  8. #7
    Jun 2005
    Dacula, GA
    155
    I would strongly recommend having the belts and tensioners (timing belt kit)replaced on both cars ASAP. The Bentley manual states the following on the same page as the table for the 1999 Maintenance Schedule.
    EDITOR'S NOTE--
    Publisher's additional recommended maintenance interval:
    *1.8T timing belt and tensioner; inspect every 20K miles,
    replace every 60k miles
    *V6 timing belt and tensioner; inspect every 20K miles,
    replace every 70k miles
    And since the the timing belt drives the water pump, it's highly advisable to replace it as well. When I did my V6, I replaced the thermostat because you have to remove the timing belt to get to it and it was bad in my case.
  9. #8
    2nd Gear
    Aug 2004
    Middletown, CT
    503
    Well, if it breaks within the next 5,000 miles, or tomorrow, then it wasn't replaced.
    No way to tell just by inspection. Maybe see if the 99 has the upgraded tensioner?
    You should have yours done right now. broken belt = serious $.
    Your wife's can go maybe to 75k, being hopefully the newer design tensioner.
    Replace: TB, tensioner, idler bearing, water pump, thermostat, all drive belts. You might also have the valve cover gasket, and cam seals replaced while the other stuff is off the car. Check for oil leaks around the perimeter of the head. Good time to replace the radiator hoses if needed, and use new permanent coolant.
  10. #9
    2nd Gear
    Oct 2001
    Cranbury,N.J.
    754
    Quote Originally Posted by vdub18t
    The old B4 Passats had timing chains in the VR6 engine . The B5 and later cars have belts .
  11. #10
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,844
    You can pull the upper cam covers and check the belt. You might be able to tell if it has been replaced,but can not be certain unless it was done recently. A year old belt will look nearly the same as a 5 yr old belt. I would go ahead and change it to be safe.
  12. #11
    Mar 2005
    17
    Thanks for the replies, looks like I'll go with preventative maintenance.
  13. #12
    Nov 2000
    Ocala FL
    1,765
    Quote Originally Posted by cooter8
    Get out your checkbook (and wallet for good measure)! Just in case you haven't been forewarned, timing belt replacement on a B5 is NOT cheap. If you're mechanically inclined, you might consider doing it yourself. Otherwise, maybe your mechanic can at least give you a volume discount for doing both cars!
  14. Remove Advertisements
