Cutting Garolite (Phenolic) sheets.
NEWS
Results 1 to 4 of 4
    May 2000
    Tempe Arizona USA
    2,396
    I bought a phenolic sheet (Grade XX Garolite) for making my own intake manifold spacer. Should I be able to use my carbide router bits to mill it? I was thinking about making a masonite template and using a router with a collar to trim and machine the spacer. Does this sound doable?
    -Mark
    2nd Gear
    Dec 2003
    Athens
    876
    yes.I've done a few before ordering at a water jet cutter.I milled and drilled the first copy.
    May 2000
    Tempe Arizona USA
    2,396
    Thanks. I've read a few pages that say this stuff can be hard on cutters and blades, but others say it cuts like butter. Just trying to figure out what's true. Maybe it is very dependant on the grade of phenolic that is being cut/milled. The XX grade is a paper reinforced phenolic.
    -Mark
    2nd Gear
    Dec 2003
    Athens
    876
    mine is a canvas reinforced phenolic resin.Lil'bit harder than yours.mills like butter though
  6. Remove Advertisements
