Check Engine light comes on after engine heats up, why?
NEWS
Results 1 to 5 of 5
    e7c
    e7c is offline
    Nov 2003
    manitoba, canada
    111
    I've got a 98 passat 1.8t, and it has an intermittant check engine light
    When the engine is cold, probably before the thermostat opens, it is fine, no CEL. When the car is at operating temperature for any amount of time, the CEL comes on. The engine still seems to run fine, temp gauge is right at 90 where it should be.
    When the car cools overnight, it is fine with no CEL.
    A few days before this started, I thought the water was low so I added a bit of distilled water to the coolant resevoir. I perhaps added too much water, I drained a bit and right now it is between the min and max level indicators, when the engine is both hot, and cold.
    Does anyone have any idea what might be going on here? I don't have access to a vag-com at this moment, but if it's undiagnosable, I'll get it checked
    e7c
    e7c is offline
    Nov 2003
    manitoba, canada
    111
    for the record, it was the ECT sending unit
    quick cheap fix
    5th Gear
    Mar 2003
    Louisville, KY
    6,172
    Good to know, for the next guy!
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,846
    What is the ECT sending unit?
    Nov 2004
    Mount Prospect, Il
    184
    It's the Engine coolant temp sender.
    It's a $6 Fix, if you do it yourself.
    VW
    RICHIE
  7. Remove Advertisements
