How to PCV Valve Replacement (2.8L V6)
NEWS
Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By codyo12
Thread: How to PCV Valve Replacement (2.8L V6)
    Nov 2008
    Camden
    23
    okay so i bought my 2001.5 B5.5 V6 passat back in august of 2008 and i started to smell oil burning well come to find out my valve cover gasket had started leaking. well as working on all kinds of motors most of the time the PCV valve is either clogged or inoperable. well mine was broken in three places from being brittle from heat and it being plastic. I did research and the only two places i found this part was ECStuning.com and the Stealership.
    Unfortunately I bought from the Stealership
    alright fresh start
    remove covers
    remove PCV unfortunately mine was horrible and finished off while removing
    left side (left nipple circled)
    right side
    there was another brittle hose on the bottom portion i fixed it temporarily beware!! also the two clamps circled i replaced those with the kind seen. the originals have to be pryed apart.
    quick fix (temporary)
    replace the clips shown here with the flat head screw in them
    finished product (right nipple circled)
    my second beauty sat right beside my first the whole time
    vg106 likes this.
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,898
    There is also another hose that runs from under the throttle body to under the intake manifold. Mine was cracked and leaked onto the trans and then the exhaust.
  4. Remove Advertisements
