FIX w/ pics: Sunroof opens & closes on its own
NEWS
Results 1 to 17 of 17
    Mar 2003
    OKC, OK - 1998 1.8t
    1,839
    My '98's sunroof has all the signs of being posessed. I've read about other people's early year model Passats having similar issues, and with the help of JohnE and TwoManyPassats in this thread, I've fixed my disobedient sunroof.
    You'll need:
    -Phillips screw driver
    -Good pencil eraser (not dried out)
    -Isopropyl/rubbing alcohol ... UPDATE: I agree with UrbanLegend (below). You should use DeOxIt as well. If you don't, you'll have to re-clean the assembly every year or so.
    -Q-tips
    -Fingernails
    ...and if your car is anything like mine, a lot of superglue to fix the plastic parts which will just come apart in your hand. (Also, possibly some sticky velcro...)
    First, make sure this fix will work for you. I think this applies mostly to 98 and 99 year model Passats... if your controller looks like mine (pay attention to the dots/lines around the rotary knob... different versions have different markings) and your sunroof tilts open on its own and/or won't go to the position you tell it to, this fix might work for you.
    First, close your sunroof. If it won't close on its own, you can put your key in the driver's door lock and hold the key in the "lock" position for a few seconds until the sunroof closes on its own. I'm not sure if this is actually important, but every other sunroof repair says to close the sunroof, so there ya go.
    Now, hop in the car and remove the little trim access panel near the sunroof control. Start at the front and use your finger or a clean butter knife to pry the edge closes to the sunroof down. It will resist you, but you can get it off. I broke my clips while taking this down (ancient, brittle VW plastic!) and had to superglue them back on. In fact, it looked like they'd been superglued before... yay.
    Now remove the dome light cover by pulling on the edge closest to the windshield.
    There are two phillips screws near the outer light bulbs. Remove these.
    Now slide the whole unit back about half an inch, and then you'll be able to remove it.
    Let the whole thing dangle by the two cords. Begin by disconnecting the blue connector on the sunroof motor that runs down to the back of the rotary knob. Next, try to remove the wiring for the overhead lights however you can figure out to. I ended up removing the whole black plug and recepticle from the back of the dome light switch. There are clips directly on the front and rear of the black conenctor that you can remove the whole thing with - this took me about 10 minutes to get off. The lights will blink on and off while you do this. Be careful -- this was brittle feeling.
    Now that you have the little panel removed, find a work area and carefully pry off the back of the rotary knob. TwoManyPassats mentioned that this is delicate, and it really is. To remove, you need to put pressure in the little slit you can see towards the back edge on either side. This will allow you to work a fingernail under the edge of the back and begin pulling it up. Mine wouldn't come off and wouldn't come off and finally I pulled on the little clips near the wires and it popped off. You can also see that the clip itself near the wire broke off. Have I mentioned the brittle VW plastic?
    Now you're practically done. First, look closely at the back of the knob you just removed.
    The contact strips on mine had some obvious wear points. I used the eraser on a nice new mechanical pencil and erased carefully over these strips in a circular motion ... clean your eraser on a sheet of paper as you go ... mine had a lot of black junk on it as I cleaned.
    Now, grab your Q-tip and get some isopropyl alchol on the tip. Wipe this in a circular motion. You're done with the back. Update: This is where you'll want to use the DeOxIt if you have any.
    Now turn your attention to the oxidized mess of contacts inside the rotary knob.
    Carefully clean them with the eraser as well -- wiping occassionally on a piece of paper. You'll be amazed how much better it looks after you're done (I forgot to take a picture...). Once erased, wipe a clean Q-tip with alcohol over the surface and let dry (and/or use DeOxIt). I also decided to use my fingernail to GENTLY bend the contact wires up closer to the electrical contact strip. It took a few tries, as I was being very careful, but it ended up working.
    Now, snap the back into the rotary knob and install everything in reverse order. I had to superglue down the metal clips on the back of my headliner access panel and also had to fasten the emergency tool with some velcro as more VW plastic had given way.
    This completely fixed the random opening sunroof issue for me. I wish I'd done it 6 months ago when I got the car, but I'm happy to know it was an easy fix. Hopefully this will fix your problems as well! Update: Using just the this problem came back twice in a 2 year period. Cleaning it would fix the problem for a while, but I finally went to Radio Shack and purchased a kit of DeOxIt. It was about $20. Now a few years later after using the DeOxIt, the problem has not reoccurred. I'm a believer -- I've also used the DeOxIt on some small electronics (a switch on a power tool that had started acting up & a shutter button on a camera) so it isn't a one-use purchase.
    (Just FYI the part number for the rotary knob on mine was 8D0 959 613. It appears that it can be replaced with 8D0 959 613 A, but that costs over $100 as of Jan 2014.)
    Last edited by macaddiict; 02-02-2014 at 01:48 PM. Reason: Clarification & image relinking
    Mar 2003
    OKC, OK - 1998 1.8t
    1,839
    Keywords:
    sunroof control , sun roof control
    sunroof controller , sun roof controller
    possessed sunroof , posessed sun roof
    sunroof won't close , sun roof won't close
    sunroof randomly opens , sun roof randomly opens
    sunroof opens on its own , sun roof opens on its own
    sunroof tilts , sun roof tilts
    sunroof knob , sun roof knob
    sun roof problems , sunroof problems
    sun roof issues, sunroof issues
    crazy sun roof, crazy sunroof
    potentiometer
    Jun 2006
    Central New Jersey
    34
    454
    Nice ! Thanks for the detailed pics. My sun roof still isnt acting wierd, but I have no reason to believe that some day it wont
    Nice touch with the keywords
    4th Gear
    Jan 2004
    Fayetteville, AR
    27
    2,650
    Good write up!
    I would not know what to think if my sunroof just opened at random driving down the road or something...
    Super (Charged) Moderator, Grinding Gears...gone fishing! ScottPassat2.8's Avatar
    Feb 2005
    Staten Is. NY GLX2.8
    45
    22,618
    great writeup!
    hey rusty, info forum move vote
  7. #6
    4th Gear
    Oct 2005
    Galesville Maryland
    3,266
    X2 on the info base! This problem is very prevalent in 98s and 99s. Doesn't seem to happen after the 2000 redesign (270 degree switch).
  8. #7
    PassatWorld Staff
    Jun 2002
    Albuquerque, 1.8T A
    12,267
    Good Stuff!
    Let's leave it here for a few days for some more exposure. Somebody remind me in a week if I haven't moved it.
  9. #8
    Feb 2005
    45
    22,618
    Good Stuff!
    reminder rusty.
  10. #9
    Dec 2004
    Pennsylvania
    28
    476
    Holy crap good idea with the keywords! Great write up!
    Mike
  11. #10
    4th Gear
    Oct 2005
    Galesville Maryland
    3,266
    Quote Originally Posted by Rusty View Post
    Good Stuff!
    How about 18 weeks
  12. #11
    Feb 2005
    45
    22,618
    Quote Originally Posted by TwoManyPassats View Post
    How about 18 weeks
    not enough time yet
  13. #12
    4th Gear
    Sep 2007
    Long Island NY
    3,768
    Electronic techs use a product called DeOxIt from a company called Caig almost exclusively. It's not the crap from Radio Shack, it's much better at cleaning and treats the metal to make it a better conductor and to prevent future oxidization. Spray it on the contacts and twist the knob a few times and your done. Virtually guaranteed never to give trouble again. Scratchy knob on a stereo, intermittent switches, fluorescent light connectors, I use it all the time .... but only once per project!
    http://store.caig.com/
    D-5 is the one you'll want, either in a spray or a rub on pen. I think Amazon has the spray for $11. And Radio Shack actually sells the pen.
  14. #13
    Sep 2006
    plano/waco, Tx
    26
    13,315
    Blog Entries
    5
    the problem with the instant spray on stuff is not that it's crap, but because it leads to the assumption that there is no necessary cleanup required.
    now, i'm not saying it's crap even though i have yet to use it, but the method outlined above is a full through to remove all debris & oxidation dust, which could potentially cause a jumped circuit.
    besides, chances are, if you've had a child in the last 5 years around your house, then you deffinitely have a bottle of isoproxyl alcohol for when that kid scrapes themself up.
    this, of course coming from a certifiable once-stupid-as-hell kid
    besides... $20 for the kit?... eek. i'l prefer the Q-tip & alcohol anyday!
  15. #14
    4th Gear
    Sep 2007
    Long Island NY
    3,768
    Quote Originally Posted by sipes216 View Post
    Yes but the Deoxit makes it so you won't ever have to do it again. It treats the metal making both a better connection than new, inhibiting future corrosion/oxidation and flushing away any foriegn particles. ( like rubber from the eraser?) You can do your laborious cleaning but there's no way I'd put it back together again without a shot of D5 for those reasons. Millions of electronic pins, potentiometers, switches and contacts cleaned and protected since 1970 something. (Do NOT use any other brand)
    $20 kit? No just one can of D5 at about 15 bucks I think that'll last years. In fact I need a new can. I just got a corroded corner bumper marker going again and did my headlight sockets when I put in new bulbs. I spray everything, even the electrical outlets in my house. I just came back to this thread because my dome light switch is acting up.
    DeoxIT helps bring old systems back to life! DeoxIT is a contact cleaner, conductivity enhancer, and lubricant. It dissolves oxidation and corrosion on metal surfaces, fills in microscopic gaps, and reseals surface for better contact to enhance the flow of electricity. It rejuvenates electrical equipment by improving connector performance and reliability. This excellent cleaner and deoxidizing agent helps protect your electronics equipment, yet does not contribute towards ozone depletion.
    CAIG DeoxIT D5S-6 Spray, Contact Cleaner / Rejuvenator, 5 oz. Features:
    Improves conductivity
    Deoxidizes, cleans and preserves
    Reduces intermittent connections
    Reduces arcing & RFI
    Reduces wear and abrasion
    Temperature range: -34 C (-29 F) to +200 C (400 F)
    Flushing action
    Safe on plastics
    Approximately 1200 applications
    http://www.musiciansfriend.com/produ...oz.?sku=429167
    (edit)Oh BIG thank's to the OP for helping me fix my dome light just now.
  16. #15
    Jan 2003
    Waterford CT USA
    27,019
    Blog Entries
    4
    just did my daughter's A4 sunroof switch using these instructions, which were mostly good for the A4... I used everyday household materials - a pencil eraser, isopropyl alcohol, and a q-tip. no need to buy anything when you have it around.
  17. #16
    Jan 2003
    Waterford CT USA
    27,019
    Blog Entries
    4
    bump so OP can easily find this to mod pix links.
  18. #17
    Mar 2003
    OKC, OK - 1998 1.8t
    1,839
    Updated thread with new image links.
  19. Remove Advertisements
There are currently 2 users browsing this thread. (0 members and 2 guests)
