Ultimate Check Engine Light thread
NEWS
Results 1 to 15 of 15
    4th Gear
    Oct 2005
    Galesville Maryland
    3,266
    Okay, so your engine light is on and you want to know why and what to do about it. Read on:
    So why is it on?
    Your engine computer (ECM or ECU) is constantly receiving data from all the engine subsystems. When it repeatedly receives inappropriate data, it flags the event by storing diagnostic trouble codes (DTC). The codes indicate specifically (I use the term specifically very loosely ) what is wrong. The ECU will also light the check engine light on your dash.
    So, can I still drive the car?
    Maybe. If the engine is behaving strangely, stalling, shaking, bucking, smoking, knocking, rattling, or anything it doesn't do normally, then don't drive it. BTW, if any of the previous conditions are normal for your car, get them fixed. If the light is flashing (not just on) then don't drive it. It means that there is a misfire and unburned fuel can enter the catalytic converter and ignite. It's not as dangerous as it sounds, but it can ruin your expensive cats. Misfires are also stressful for your rods, crank, and engine mounts.
    How do I get rid of it?
    Slow down. It's really best to find out what's going on. Some auto parts stores like Autozone will read your codes for free. You can also find another member with a code reader or buy one of your own. If you own a VW, I'd recommend a Vag-Com from RossTech. Once you have the codes, google them and you should be able to find out what they mean and sometimes a solution. Adding the make and/or model of your car will help narrow the search.
    Can I just clear the code and cross my fingers?
    Sure, if there is a real problem it will come back to haunt you soon enough.
    I don't have time to figure out what's going on. Can't I just do a bunch of random stuff in hopes of fixing it?
    Maybe. There are eight subsystems that fall under OBD-II standards- EGR, O2 sensor heaters, O2 sensors, air conditioning (?), secondary air injection, evaporative emissions, catalyst heating, and catalytic converters. Just about anything could be causing the code(s). Here's some things you may want to check first. Make sure your gas cap is on and seated at least three clicks. Open the hood and take the fancy covers off the engine. Look around the engine bay for any disconnected connectors or cut wires. Also look for any frayed or cracked vacuum lines.
    So how do I know if my repair worked?
    Many of the DTCs will clear themselves after a certain amount of good data is received. This sometimes can take weeks. The best thing to do is start off fresh by resetting the ECU. The same person who read your codes can do this. Resist just disconnecting the battery. You may cause your fuel system to reset requiring a throttle adaptation. You will also put your radio in safe mode.
    So I'm all clear. Can I get my emissions test now?
    Sort of. The eight OBD-II categories have readiness codes. All eight need to be at ready to pass an emissions test. A fifteen mile drive should do it, BUT you need at least one start from cold and part of the trip has to be at highway speed. Turn on the AC once too.
    How much will this cost me?
    How much you got? Luckily, most states have a limit on what you need to spend before they give you a freebie. In many cases, the fixes are as simple as connecting a vacuum line or connector (about $150 at your local dealer).
    For search purposes- OBD OBD-II DTC MIL CEL emissions emmisions emmissions check engine light malfunction indicator lamp diagnostic trouble code
    Apr 2004
    SoCal
    2,117
    Cliffnotes...
    1.Check engine light turns on...
    2.Go to autozone to get it read for free (if your car drives fine)
    3.Fix the problem with help from passatworld
    4.clear your codes
    5.Test drive it for 30 or so miles and see if CEL comes on at all
    6.Car is safe to be inspected
    The end...
    (PS...isn't this all just common knowledge?)
    4th Gear
    Oct 2005
    Galesville Maryland
    3,266
    Quote Originally Posted by sonnybk
    ...(PS...isn't this all just common knowledge?)
    Absolutely, but every two days there's a thread asking about CELs. Though this would save us time writing the same thing over and over.
    Super (Charged) Moderator, Grinding Gears...gone fishing! ScottPassat2.8's Avatar
    Feb 2005
    Staten Is. NY GLX2.8
    45
    22,618
    Quote Originally Posted by TwoManyPassats
    never happen!
    the deal finder!
    Feb 2004
    LA, CA
    15,571
    just to point out that you can't search for 3 characters in this forum.
  7. #6
    Jul 2004
    Vancouver, BC
    29
    1,072
    this is a good thread for people new to vw's. good info
  8. #7
    4th Gear
    Oct 2004
    Encinitas CA
    4,544
    I just got another gas cap triggered CEL. I happily noted that it self-cleared two engine starts after I tightened the cap a couple of clicks.
  9. #8
    Feb 2005
    Duluth, MN
    1,890
    My only question is where did you hock this from?
  10. #9
    Feb 2006
    San Diego
    126
    P1519 "A" Camshaft Position Actuator Bank 1 (BMW)
    ok P1519 is the code that has been cooming up on my v6 b5 every couple of thousand miles. the car runs fine with or with out the CEL on i just get it reset at autozone when it happens.
    the first time it happend was when i hit a couple potholes. bow it comes on when i run the engine a little too hard.
    anyone have any idea or fixes on this?
  11. #10
    Feb 2004
    Midcoast Maine, USA
    1,057
    Quote Originally Posted by D.Passat00
    You can if the moderators make it so for the specific 3 character search. Try 1BE for instance. Search works!
  12. #11
    4th Gear
    Oct 2005
    Galesville Maryland
    3,266
    Quote Originally Posted by V-Dub Duluth
    Hock? I wrote it.
  13. #12
    Feb 2005
    Duluth, MN
    1,890
    Color me impressed. Apologies if I offended you. Great writeup!
  14. #13
    4th Gear
    Oct 2005
    Galesville Maryland
    3,266
    NP. I used to do a lot of technical writing in a former life.
  15. #14
    4th Gear
    Oct 2005
    Galesville Maryland
    3,266
    Seasonal bump
  16. #15
    PassatWorld Staff
    Jun 2002
    Albuquerque, 1.8T A
    12,267
    How about a move to Info Forum?
    Good post - thanks for the seasonal bump.
  17. Remove Advertisements
There are currently 4 users browsing this thread. (0 members and 4 guests)
