Need wiring Diagram for 6 CD Changer
NEWS
Results 1 to 15 of 15
    Sep 2004
    Naperville Illinois
    30
    1999 1.8T
    My Passat was killed (another story) I removed the 6 CD changer (trunk mounted) before the car was taken away but left two CDs in the cart. I am looking to put power the the unit to eject the cart but do not know what color the Hot is (black)?? Assuming white is neutral. Does anyone have a wiring diagram that shows this and what voltage can be applied?
    Colors on the plug are:red, blue, white, yellow, purple, black, orange, brown, green.
    Anyone interedted in the unit??
    thx
    Super Stealth Moderator
    Jan 2003
    Waterford CT USA
    25,781
    Blog Entries
    3
    black is usually ground, and brown is usually 12V for VW. I'd hook 12 V betweeen those and try to eject.
    99 GLS, 2.8 V6, Leather, Cold Weather pkg, driven 120 miles/day, Mon-Fri
    I has a sig!
    Sep 2004
    Naperville Illinois
    30
    many thanks
    Punches Dubs. True Story
    Mar 2005
    Butler Lake Park
    35
    9,985
    Blog Entries
    48
    Like I said in the other thread, wouldn't power (12V) be the yellow?
    Oops, that the signal from the radio that turns the unit on and off. Hence the reason I tapped it as my REM lead from my amp. Jeez ...it's a wonder i get out of bed anymore.
    Jan 2003
    Waterford CT USA
    25,781
    Blog Entries
    3
    Quote Originally Posted by traubenberg View Post
    its ok, traub. you also said there was no room for your sub amp in that varient.
    until you actually LOOKED.
    I has a sig!
  7. #6
    Mar 2005
    Butler Lake Park
    35
    9,985
    Blog Entries
    48
    Um ...I had to remove the entire shelf-dealy to cram that bitch in there, too.
  8. #7
    Sep 2004
    Naperville Illinois
    30
    12V across Brown (+) and Black (-) didn't work. no noise, nothing. any other thoughts?
  9. #8
    Mar 2005
    Butler Lake Park
    35
    9,985
    Blog Entries
    48
    Go to your local VW dealer and ask them to pop the trunk on a B5 so you can plug in your changer and get a couple of CDs out?
  10. #9
    Jan 2003
    Waterford CT USA
    25,781
    Blog Entries
    3
    there is also a yellow or gray wire in the harness. try putting +12V to it as well (in addition to +12V on the brown lead and ground the black lead) - it is the remote power lead.
    I has a sig!
  11. #10
    Mar 2005
    Butler Lake Park
    35
    9,985
    Blog Entries
    48
    So, Jay ...which is it? You gonna side with using the yellow wire or not?
  12. #11
    Jan 2003
    Waterford CT USA
    25,781
    Blog Entries
    3
    if it works to eject his CDs, why not? but power applied to the remote alone won't do it.
    the reason I had him apply power first to the brown and black wires is it should have allowed him to at least eject the CDs.
    if that doesn't work, then I'd try 12V to the red and ground the brown.
    I has a sig!
  13. #12
    Feb 2005
    L.A.
    243
    I posted the CD changer cable pinout in this thread...
    Phatbox (or CD changer) alternator whine fix.
  14. #13
    Mar 2005
    Butler Lake Park
    35
    9,985
    Blog Entries
    48
  15. #14
    Jan 2003
    Waterford CT USA
    25,781
    Blog Entries
    3
    Quote Originally Posted by Phiow View Post
    your post doesn't have the pinout per color as to what color wire does what, nor does it state which pin number has power, ground, remote, or signal.
    I has a sig!
  16. #15
    Feb 2005
    L.A.
    243
    Sure it does... Pin 3 is ground, pin 6 is power, pin 8 is remote. Look again.
    Those pin numbers are visible directly on the connector housing in the trunk. You don't need wire colors, and I wouldn't trust them to be consistent, anyway. (I've seen at least two color schemes.)
  17. Remove Advertisements
