Double Platinum vs. Iridium
NEWS
Results 1 to 8 of 8
    Sep 2010
    NoDak
    22
    292
    Hey guys,
    In general, whats the difference between say, double platinum and iridium plugs?
    The reason I'm asking is because I'm about to do the plugs on the rents' '04 Town Car and those Triton engines are a chore to change the plugs on. They have the coil-over-plug setup, plus the back few are still hard to get to, even when you remove the fuel rails and such. I know this because of our F-150!
    The book says its supposed to take over 2 hours, which means me and my sweet time will take all day.
    I don't want to have to do this again for a really long time, so I was going to go with the Double Platinums because they should last well over 100,000 miles.
    It's my understanding that Iridium's perform overall better, but don't last as long. Am I correct? <<< Here's the question (for those who don't wish to socialize)
    Double Platinums - NGK Spark Plugs 7740 - NGK Laser Platinum Spark Plugs - Overview - SummitRacing.com
    Iridium - NGK Spark Plugs 6044 - NGK Laser Iridium Spark Plugs - Overview - SummitRacing.com
    And if you're wondering, the Passat's plugs get changed every 40,000, whenever I get there.
    Yes I really do care this much about spark plugs.
    Jul 2008
    A Cardboard Box
    13,539
    No spark plug is going to last 100,000 miles, not effectively anyways. As far as the whole process taking two hours, I'm not so sure about that. Here's a video that shows how to replace them:
    GL, and I think your best bet for spark plug recommendations is going to be on a Town Car forum.
    Sep 2010
    NoDak
    22
    292
    After reading your post, I had to go pop the hood and look because I was confused. The engine on your video isn't the same as mine. There's a few differences, which Ford must have revised.
    But you're right, I guess it's not as bad as I thought. The hood is so large, you can get to the whole engine. The motors are sunk so far back in the pickups.
    I beg to differ. This has 109,000 miles is on its original set. The car runs/idles smooth, with the gas mileage still about 25. We bought the car a few months ago, and I freaked out a little when I realized they hadn't been changed yet. I better not snap one off.
    We also have a '97 Buick Lesabre with the 3800. I replaced those while trying to diagnose what ended up to be a cracked coil tower. I had to tear off the original Packard metal covered plug boots. Original AC plugs at 103,000 miles. The ground strap was definitely worn, but was at worst, twice GM's huge .060 recommended gap.
    I'll agree that they're probably not as efficient, but if your cylinders aren't running too rich or lean, there's a good chance they'll last.
    But I'm not going to try to run a set of plugs over 100,000 on purpose.
    These American cars can definitely take more abuse than German autos. They most certainly are far from the overall driving experience, however.
    NO! lol. Anytime I go looking for other forums, its just disappointing because none even come close to PassatWorld.
    I don't need a recommendation. Just a general answer to how iridium plugs compare to double platinum.
    Jul 2008
    A Cardboard Box
    13,539
    Quote Originally Posted by mount View Post
    Performance may not be noticeably compromised on a Town Car, but gas mileage and performance issues aside, having a spark plug sit in an engine for a decade is just asking for it to seize up. I realize you can drive it for 100k with the original plugs, but I wouldn't recommend it, even on a domestic/import.
    As far as durability goes, Double Platinum's will last a bit longer versus the iridium if you just want the longest lasting plug.
    Sep 2010
    NoDak
    22
    292
    I concur with this. I still can't believe how some people don't use anti-seize on their threads.
    Thanks for the info and cheap entertainment. Thats why I love this forum.
  7. #6
    2nd Gear
    Mar 2001
    South Carolina
    752
    I think the reason you are finding so many people not using anti seize on their plugs these days is because that is the correct way to install them. At least it is the correct way to install those specified for the passats I have worked on - and most every other car.
    http://www.ngksparkplugs.com/pdf/TB-...1antisieze.pdf
  8. #7
    Jan 2009
    KW & Toronto
    13
    2,024
    Thanks for the link to the document, I will not use anti-seize on my next plug set.
  9. #8
    Jul 2008
    A Cardboard Box
    13,539
    Quote Originally Posted by Toronto5.5 View Post
    Bosch plugs are nickel plated as an anti seize measure.
  10. Remove Advertisements
