I'm working on putting my snow tires on my passat, but my wheels are stuck on. I got all of the lug nuts out, but the god d*mn wheels are stuck on. I tried spraying some wd-40 around the centering hub to try to help break it free, but so far no luck...
Any ideas how to remove the d*mn wheels and prevent them from sticking in the future?
kick the tires!!!(not the rim) left then right...then up and down....maybe it will take 1-4 rounds of kicking...thats what im usualy doing when they r stuck!
Hope that helps
No luck, I hadn't though of sitting and kicking, makes sense, however they still will not budge. These suckers are stuck. I bet I could drive around the block without the lug nuts.
I broke the wheel removal tool last year, but I wouldn't mind having the tire fall on me as that would be progress. It's just been one of those weeks…
What kind of wheels are they? if there is space enough, try getting underneath the car and hitting the inside of the wheel with a hammer right next to mating surface with the hub, going around it. Or you can try a large rubber mallet from inside the wheel. If you have steel wheels and are adventurous, you could try heating the wheel next to the mating surface with the hub with a propane torch. Don't use WD-40, get "high performance penetrating lubricant" from Lowe's, and be sure not to get it on the rotors or pads. Oh, and don't try the last step before the torch or your a$$ will be on fire. Good luck :thumbup:
If your too little to kick it, then find somebody thats got some weight behind them and kick it. Im 194 lbs and one swift kick usually displaces my wheels.
Put the lug bolts back in and leave them turned out about 2 turns. Put the car back on the ground and shake the shit out of the car. If that fails, slowly drive around your neighborhood. Only turning out the lug bolts two turns will still keep the wheel on the hub and won't damage anything. This is better then having the car fall off the jack from kicking too hard.
Finished!! After 2 days of kicking, spraying, waiting, dropping the car, spraying, kicking, etc, etc the wheels poped off. I put some copper based antiseeze on the mating surfaces, so hopefully that will make remove the snow tires in 4 months easier. God I don't want have to go thru that again, it sucked.
Thanks all.
Related Threads
Volkswagen Passat Forum
3M posts
158.8K members
Since 2002
