Broken Glove box door latch (2002)
NEWS
Results 1 to 28 of 28
Like Tree1Likes
  • 1 Post By djm777777
Thread: Broken Glove box door latch (2002)
    Oct 2001
    Weare, NH
    20
    I went to close the glove box yesterday and it would not latch closed. The latch pins were even with the edge of the door and the handle had gone limp. Anyone else experienced this failure?
    JOE
    JOE is offline
    2nd Gear
    Sep 2001
    Waterbury CT
    806
    Re: Broken Glove box door latch (jemac)
    Yup, I have. I took it apart by unscrewing all the little screws around the edges on the inside and super glued the 2 long pins in place. Part of the plastic that holds the pins was broken and the handle was not working. I have not had a problems since.
    Aug 2001
    4,653
    Yup, me too. Dealer replaced it at 22k miles.
    Jun 2002
    Atascadero CA USA
    387
    yep happened here as well. you should have seen the gizmo I made to hold it shut I could not settle for tape, I had to make a retaining system out of paperclips and rubber bands
    Aug 2001
    Granville, MA, USA
    18
    Hmmmm. My latch broke after I closed it, two days ago. Can someone post a picture of the latch mechanism when it's open so I can try to pick the lock or if anyone has had my experience, share how they dealt with it?
  7. #6
    Jun 2001
    Westchester County (NY), 200
    35
    1,430
    Re: Broken Glove box door latch (DeviantVariant)
    this happened to me too a coupl eof days ago..can the dealer fix under warranty?
  8. #7
    Aug 2001
    Granville, MA, USA
    18
    Re: Broken Glove box door latch (aldolicious77)
    Yes, if you are still under warranty they will fix it. At least they did fix it for someone I work with. Unfortunately, I'm out of warranty.
  9. #8
    May 2002
    Freehold NJ _____02 GLX 4motion____ ***roger da sweepa***
    1,750
    one has been "limp'' ever since i got the car...i always forget to tell the service guy....
  10. #9
    2nd Gear
    Apr 2002
    Shoreview MN USA
    889
    Re: Broken Glove box door latch (4meezy)
    <BLOCKQUOTE>quote:<HR>one has been "limp'' ever since i got the car...i always forget to tell the service guy....<HR></BLOCKQUOTE>
    Just wait for the improved Viagra
  11. #10
    Aug 2001
    Granville, MA, USA
    18
    It seems a number of us have had the broken glove box experience, so it's likely that some more of us will. I wanted to post some help for future "glove boxers." Everyone who posted on this thread had their door fail open, mine failed closed. I used a coat hanger snaked into the box and looped around the dead bolt, which is beveled on the engine side, to pop open the door.
    http://users.murtari.com/ejack/Glovebox1.jpg
    As you can see by the photo, there are two individual cams that operate, when the door lever is pulled. The lever pushes down on the cams. Each cam pulls the dead bolt back on each side of the box. The cams pivot on plastic posts that are flared on the ends to keep the cams in place. In the case of my box failure the flared plastic piece had broken and a cam had fallen off its pivot post. Referring to the picture again, you can see that I have installed screws onto the ends of the cam posts to ensure that the cams cannot fall off again. It's all pretty simple once you know how the mechanism works.
  12. #11
    Oct 2001
    Weare, NH
    20
    Well, I got back from the dealer with the glove box door replaced under warranty. I did have to remind them that the 2002 have a 48,000mile warranty, NOT a 24,000 mile warranty though.
  13. #12
    2nd Gear
    Dec 2001
    Long Island NY USA
    573
    Oy, this just happened to me. I'm just put some air into my tires, and was when I opened the glove box to replace my pressure gauge, it wouldn't close. I have a service appointment in under two weeks, so I guess I'll just tape it closed until then. I'm almos at the 1 year mark (two shy) and 21K miles.
  14. #13
    Jul 2003
    Baltimore-Washington
    5
    You can add my 2001.5 wagon to the list of passats with a broken glove box. It happened last week. So I had the dealership give me an estimate today when I took my car in for the two recalls that came out this June & July. I was thinking $100 bucks or so (I'm not under warranty), and was going to give them grief about that. I couldn't believe it when they came back with an estimate of $314!!!!!!!!!!. $150 for the part and the rest for labor. This is the same dealership, Ourisman of Laurel, MD. that wanted $66 to replace the right headlight. Anyway, thanks for your creative suggestions on how to DIY. Hopefully I can have it working this evening and can put away the calking gun I've been using.
  15. #14
    Dec 2002
    NJ
    2,381
    My glove box is hard to close, you basically have to slam it. The pins are lined up correctly and push in easily with a finger, but it's still just hard to get it shut. I guess I'll soon have to take it into the dealer.
    Some times I think about buying the car out at the end of the lease since I did some mods and chipped it. I really love the car, but I hate these little problems that end up costing you money and time.
  16. #15
    Jul 2003
    5
    Here is what I ended up doing to fix the glove box door. Rather than messing with strings, wires, latches and other gizmos, I went with Velcro (12" from auto store $3). I like this because it preserves the pull-down functionality of the glove box. It was also simple, fast, and ended up not looking half bad. It required superglue for fastening since the adhesive that comes attached to the velcro slips off at high temperatures. I put the full strip (soft side) across the inside top edge of the glove box door. The rough side went underneath the top of the glove box compartment where it would meet upon closure. I found that I had to use three 2"-3" pieces on top because the velcro was too strong (the door too hard to open) when all 12" met all 12", if that makes any sense. Anyway, there is plenty of strength, it looks good, and functions normally. The only thing I'm out now is the lock, but I can live without that. I have pictures but nowhere to put them on the web, which I guess is necessary to get them in this post. I can email in case you are interested.
    heatha1984 likes this.
  17. #16
    Jun 2001
    Derry, NH, Rockingham
    21
    Ditto,
    Mine is a 2001.5 and happened right after I bought it. Dealer replaced the lock under warranty. Never had this happen to any car I've ever owned. Now it's in the shop for the rear trunk lock.
  18. #17
    4th Gear
    Sep 2001
    Chicago, IL
    3,529
    Mine broke at 23800 miles...got it replaced under the 24000 mile warranty...phew
  19. #18
    Jun 2001
    Erial, NJ
    16
    Yeap I had the same problem in the closed position. First time they tried to fixed it the glove box door did not line up-I could see inside the glove box by the gap they left when it was closed. Eventually the dealer replaced the glove box door under warranty. Now I am out of warranty so I close the glove box very carefully.
  20. #19
    Aug 2001
    Granville, MA, USA
    18
    These are NOT your typical American made glove boxes. They do not have the latch in the center of the door, but have pins that slide into slots on either end of the door. The door is also on a geared tram and slamming the glove box shut (like I used to do with all glove box doors) is a bad thing. :roll:
    One can view and access part of the glove box works by pulling off the side panel at the end of the dash. It's the same kind of panel that covers the fuses, but on the other end. :shock:
  21. #20
    Jun 2001
    35
    1,430
    add my name to the list too..happened to me awile back...what a pain in the ass.....i had to crack it all open then super glue it back...thank god it worked out
  22. #21
    2nd Gear
    Dec 2002
    Boston, MA USA
    628
    Do you keep your manual in your glove box? Just curious....
  23. #22
    Tre
    Tre is offline
    2nd Gear
    Mar 2001
    Washington, DC, USA
    3
    801
    My glove box lock broke under warranty and was repaired free of charge. Tonight it broke again! What junk!
  24. #23
    Jun 2003
    Pico Rivera, Cali
    171
    my glove box broke too. now i dont have ahndle on it and i have to press down a latch with my finger to get it open. oh and the right latch never worked well. it would always get stuck.
  25. #24
    Tre
    Tre is offline
    2nd Gear
    Mar 2001
    Washington, DC, USA
    3
    801
    The Fix
    UPDATE: FIXED! - many thanks aldolicious77
    I repaired my glove box with two short, fine-thread screws, two thin washers and Krazy brand glue. I used a box cutter, flat head and hex head (i think that's the one) screw drivers, and two clamps. Here's how:
    1. Remove the seven hex head screws and remove glove box
    2. Pry the door face from the door with the box cutter then slide the flat head screw driver along the door edge to crack the seam
    3. Reseat mechanism and spring and insert a screw with washer in each of two pegs - test latch
    4. Apply Krazy glue to the door
    5. Apply Krazy glue to the door face, too - one side not strong enough
    6. Clamp glove box closed for a couple hours
    7. Replace in car and rejoice!
  26. #25
    Jan 2012
    Jensen Beach, FL
    4
    The velcro was my thought exactly! I'm having the same issues with my 2000 Passat glove bo. Thanks for all the helpful tips
  27. #26
    2nd Gear
    May 2000
    tucson, az
    537
  28. #27
    Apr 2011
    Richmond, VA
    4
    Hello, my glove box failed closed as yours did. I tried to look at your picture, the link does not open it. Can you send the picture? Did you use the coat hanger on each side of the door to pop the door open? I have 2003 Passast, it seems to have a latch on left and right side of the door.
    Thanks
  29. #28
    Super Stealth Moderator
    Jan 2003
    Waterford CT USA
    25,852
    Blog Entries
    3
    Quote Originally Posted by mysman View Post
    Quote Originally Posted by gpelais View Post
    Thanks
    the pix in the link above work fine for me.
    99 GLS, 2.8 V6, Leather, Cold Weather pkg, driven 120 miles/day, Mon-Fri
    I has a sig!
  30. Remove Advertisements
