Hoping that I can get some assistance with the following codes:
Wednesday,20,August,2014,11:44:27:55062
VCDS Version: Beta 12.10.3
Data version: 20130228
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: Mileage: 252360km/156809miles
Address 01: Engine Labels: 06B-906-018-AWM.clb
Part No SW: 4B0 906 018 CM HW: 8E0 909 018
Component: 1.8L R4/5VT G 0010
Coding: 0016551
Shop #: WSC 06417 444 84007
VCID: 6ED879D27A40136E6D9
7 Faults Found
17887 - Brake Boost Vacuum System
P1479 - 008 - Mechanical Failure
16395 - Bank 1: Camshaft A (Intake)
P0011 - 002 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
16727 - Camshaft Position Sensor (G40)
P0343 - 001 - Signal too High - Intermittent - MIL ON
17522 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 008 - Internal Resistance too High - Intermittent
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller - Intermittent
17964 - Charge Pressure Control
P1556 - 002 - Negative Deviation - Intermittent
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 001 - System too Lean - MIL ON
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 3B0 927 156 AH
Component: AG5 01V 1.8l5VT USA 0810
Coding: 0001104
Shop #: WSC 06417 444 53269
VCID: 6CDC73DA4C5CE17E43D
1 Fault Found
18158 - Supply Voltage
P1750 - 003 - too Low - Intermittent
Freeze Frame:
RPM: 224 /min
RPM: 64 /min
RPM: 0 /min
(no units): 0.0
Torque: 88.0 Nm
Temperature: 81.0°C
T.B. Angle: 0.0°
(no units): 4.0
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00021
Shop #: WSC 00028
VCID: D3AE48262122DE86E27
2 Faults Found
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - Intermittent
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 C
Component: 09 AIRBAG VW6 04 0004
Coding: 12345
Shop #: WSC 00028
VCID: 37769CB6159A92A67EF
No fault code found.
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 927 B
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 07235
Shop #: WSC 00222
VCID: 244C5BFAB40CE93ECBD
WVWPD63B12P243152 VWZ7Z0A4396051
1 Fault Found
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: F0E4E7AAB074859EFF5
1 Fault Found
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 08 Komfortgerát HLO 0001
Coding: 00258
Shop #: WSC 00028
Subsystem 1 - Part No: 1C1959801
Component: 08 Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C1959802
Component: 08 Tõrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1C0959811
Component: 08 Tõrsteuer.HL KLO 0002
Subsystem 4 - Part No: 1C0959812
Component: 08 Tõrsteuer.HR KLO 0002
1 Fault Found
00913 - Window Regulator Switch; Front Right Driver (E81)
27-10 - Implausible Signal - Intermittent
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180
Component: Radio NP2 0007
Coding: 00401
Shop #: WSC 00000
VCID: DDBAAE1E57E618F6443
5 Faults Found
00878 - Connection to Speaker Front Left
36-00 - Open Circuit
00879 - Connection to Speaker Front Right
00880 - Connection to Speaker Rear Left
00881 - Connection to Speaker Rear Right
01042 - Control Module; Not Coded
35-00 - -
End ---------------------------------------------------------------------
Thanks in advance
Miles2Go
Coding: 0016551
7 Faults Found
Coding: 0001104
1 Fault Found
Freeze Frame:
RPM: 224 /min
RPM: 64 /min
RPM: 0 /min
(no units): 0.0
Torque: 88.0 Nm
Temperature: 81.0°C
T.B. Angle: 0.0°
(no units): 4.0
Coding: 00021
Shop #: WSC 00028
2 Faults Found
Coding: 12345
Shop #: WSC 00028
Coding: 07235
Shop #: WSC 00222
1 Fault Found
Coding: 00006
Shop #: WSC 00028
1 Fault Found
Coding: 00258
Shop #: WSC 00028
1 Fault Found
Coding: 00401
Shop #: WSC 00000
5 Faults Found
35-00 - -
Thanks in advance
Miles2Go
