Climatronic
NEWS
Results 1 to 4 of 4
Thread: Climatronic
    May 2011
    ct
    65
    Climatronic
    I have a 01 passat v6 with Climatronic control. When i got in the car yesterday I hit the defrost button . No fan the Climatronic says off . no matter what i hit nothing happens . The blower motor has be making noise for a while . Would a bad motor cause this . Thanks it is cold
    4th Gear
    Nov 2003
    Raleigh, NC
    36
    3,709
    Get yourself an OBD-II cable, a copy of VCDS-lite, and scan Climatronic for codes.
    Nov 2008
    UK
    9
    if the blower doesn't come on when you want it to, give the glove box area of the dash a thump with your hand. If the blower kicks into life then your brushes in the blower are worn. This is a VERY common fault. I sold thousands of replacements brushes in the UK. I no longer sell them but they are still widely available in the UK on ebay. If you dont want to order brushes from the uk, get a similar sized set of carbon brushes from a power tool etc and chop them down. You can also pull your old brushes out of your blower motor and rotate them through 180 degrees. The taper on the end is then reversed and this is regularly enough to get the blower working again temporarily.
    Hope this helps
    Baz
    VW Passat & VW LT35 Heater Blower Motor Carbon Brushes | eBay
    4th Gear
    Feb 2013
    Bendigo, Australia
    4,179
    The brushes might be worn, but don't rotate them 180 degrees, that can damage the commutator, and wouldn't last long anyway.
    Check fault codes and post results.
    See this self diagnostic test. (Read second paragraph before using)
    http://www.saunalahti.fi/~jues/Clima...iagnostics.pdf
    NOTE: Actuator test: Should read, Battery Voltage >11.5 <15.5V.
    The self diagnostics might not work because of the fault. If not, use VCDS.
  6. Remove Advertisements
