no start no spark
NEWS
Results 1 to 6 of 6
    Nov 2009
    Tulsa, OK
    56
    no start no spark
    My car died on me. Its a 2000 atw a4. I noticed theres no spark on all 4 cylinders. Pulled the crank positiin sensor and it was covered in oil on the inside. Wiped it clean installed back and car purrs like a kitty. 3 days later same thing happened. Why am I having so much oil on my flywheel?
    4th Gear
    Nov 2009
    Upstate NY
    3,239
    Leaking rear main seal.
    Nov 2009
    Tulsa, OK
    56
    Could it be transmission seal? Torque converter?
    4th Gear
    Oct 2004
    Encinitas CA
    4,462
    Quote Originally Posted by MafiaBoy View Post
    Is the fluid reddish (transmission) or amberish (engine)?
    Nov 2009
    Tulsa, OK
    56
    Redish. But i think it's my coolant dripping from the oil cooler and soaking through the seal on the sensor.
  7. #6
    4th Gear
    Feb 2013
    Bendigo, Australia
    4,189
    Fix the coolant leak first, and see if that helps the sensor problem.
  8. Remove Advertisements
