How to unplug ABS module?
NEWS
Results 1 to 19 of 19
Like Tree2Likes
  • 1 Post By Matt98B5
  • 1 Post By 1.8t_noob
Thread: How to unplug ABS module?
    Oct 2012
    NYC
    45
    I'm trying to unplug the ABS module to see if my tach will start working because I am tired of looking at a dead tach needle. I went to a shop to scan for any codes and nothing came up so imma try this option.. Can anyone tell me or show me where to u plug the abs module ? Thanks !
    Nov 2000
    santa cruz ca
    330
    Assuming (from your screen name) that it's a B5: ModuleMaster | 98-01 VW Passat Info
    Oct 2012
    NYC
    45
    Sorry for not specifying but yea it's a b5... Wait so I just can't disconnect it? I have to take the whole thin out? Sorry I'm a lil slow lol
    Oct 2012
    NYC
    45
    one more thing...i dont actually know if its the same common problem as other b5 members becasue my tach doesnt work at all only only works once in a blue moon but when it does decides to work the oil light will come on and start beeping, but i dont know if the ABS/brake light comes on because i have feeling the light on the cluster for ABS/BRAKE blew out...so should i still try to unplug the ABS module? and does unplugging the ABS module mean taking the whole thing out of the car? or just like pulling one plug? im brain dead when it comes to these stuff lol
    Apr 2004
    Sacramento, CA
    26
    271
    If you can reach it, you should be able to just unplug the connector (step 4 on the Module Master page). I believe you will get an ABS warning of some kind on the dash when you do this, but it may get the tach working again.
    xLSxGaia likes this.
  7. #6
    Apr 2012
    Los Angeles, CA
    9
    I don't know about your instrument cluster problem, but if you want to scan for codes then you only need to remove the two connectors from the abs module, not the whole module itself. That link should give you all the help you need, I used the same one when I tried to get my code reader to work.
  8. #7
    Oct 2012
    NYC
    45
    ok thanks matt, i'll try this when i get home..
  9. #8
    Apr 2004
    Sacramento, CA
    26
    271
    After reading a little more (including 1.8t_noob's post), I think there are 2 connectors. I had forgotten that.
    Good luck!
  10. #9
    Oct 2012
    NYC
    45
    Quote Originally Posted by Matt98B5 View Post
    Good luck!
    So im guessing it's step 3 and 4 from the link ? And it's fine driving it disconnected too right?
  11. #10
    Apr 2012
    Los Angeles, CA
    9
    yup step 3 and 4. yes its essentially driving without having abs but the brakes are still fine and if the abs module wasn't working to begin with then you wouldn't have abs anyway
    Redb5 likes this.
  12. #11
    Oct 2012
    NYC
    45
    Ok I just unplugged one connector because in the process of disconnect the connector in step 4 I kinda broke the clip lmao. But the tach is working now so I'll just leave it till another time to figure out how to disconnect it with a broken clip .. But thanks for the info guys
  13. #12
    Dec 2005
    san diego
    80
    3
    after unplugging the main connector to the abs ,the red abs light will come on with all wistles and bells.do not worry:just cut black plasticelectrotape 2 inches and tape it over the useless indicator lamps inside :simple stoneage tech,but it works fine and does not make you any more nervous!good luck bushdoctor
  14. #13
    Oct 2012
    NYC
    45
    Quote Originally Posted by bushdoctor View Post
    The ABS light doesn't come on but I have a new problem and that's te oil light that's constantly flashing ...is that because I didn't unplug the second connector?
  15. #14
    Apr 2004
    Sacramento, CA
    26
    271
    Have you used a pressure gage to make sure your oil pressure is ok? If the low oil pressure is actually triggering the light (which I would think it is now that you've unplugged to likely broken ABS module), you don't want to be driving that car until you get that figured out.
  16. #15
    Oct 2012
    NYC
    45
    damn... i might just have to go and check on it now..so the oil light isnt suppose to come on when i disconect the ABS module right?
  17. #16
    Apr 2004
    Sacramento, CA
    26
    271
    Also, I believe the oil pressure warning on the dash is disabled while the engine is under 2000 rpm, so you can't tell that way. The only real way to check is to hook up a pressure gauge to the oil system. Significantly lower than that, and there are likely to be lubrication problems within the engine. I have a 1.8t, not a V-6 (I think that's what you have from your profile page), so I'm not too familiar as to what to look for there other than the obvious - possible oil pump or major leak problem, or low oil level. I know V-6s do generally burn more oil, so maybe you accidentally let it get a little low?
  18. #17
    4th Gear
    Nov 2003
    Raleigh, NC
    35
    3,166
    Why'd you stop with just the first connector? The ABS module can cause all sorts of fascinating problems; pull the second connector and then you'll be working with a system in a known state.
  19. #18
    Oct 2012
    NYC
    45
    At first I only disconnected the itsy connector cause I couldn't find the second one cause it was too dark.. But even after disconnecting both connectors te oil light still flashes consistently
  20. #19
    Mar 2011
    Chicago
    302
    I would say it mgiht be something with the system. As I had my factory oil pressure sender unplugged for a few days after I got my oil gauge installed and it would only sound when the car ran over 2k. When the car got back under the light would go off until i get above 2k again and after a few times it would stay on till i cut the car off.
  21. Remove Advertisements
